7D vs. 60D
14 replies to this topic
#1 ben goldberg
ben goldberg
  • 19 posts
Posted 07 April 2011 - 06:06 PM
So I have been thinking about purchasing a 7D or a 60D, just trying to get out to do some more shooting while things are slow and not looking to spend all of my money.
I know they both have fairly similar characteristics. If you have used both could you tell me if it is actually worth that extra 500 or so dollars to go with the 7D as opposed to the 60D?
#2 Kemalettin Sert
Kemalettin Sert
  • 84 posts
  • Digital Image Technician
  • Istanbul
Posted 07 April 2011 - 06:09 PM
i have 7D and built is better than 60D...thats all i can say
PQ is almost same
#3 Joshua Larson
Joshua Larson
  • 5 posts
Posted 07 April 2011 - 10:44 PM
The 60d has One Digic 4 processor, the 7d has 2. This allows for more latitude, in both video and photos, better high iso handling, and better videorecording (the codec is recording a stronger file)
Edited by Joshua Larson, 07 April 2011 - 10:45 PM.
#4 Tim Tyler
Tim Tyler
    Administrator
  • Admin
  • 1295 posts
  • Olympia, WA (US)
Posted 07 April 2011 - 10:58 PM
...This allows for more latitude, in both video and photos, better high iso handling, and better videorecording ...
I don't think so.
The second processor makes processing still images shot in quick succession faster, but has no effect on video processing.
AFAIK, video quality on both cameras is identical.
#5 Meghan Pangiochi
Meghan Pangiochi
  • 1 posts
  • Bucks County, PA
Posted 04 May 2011 - 01:03 PM
I've used both the 7D and the 60D, and the 7d does feel substantially more solid.
The image quality is the same, though the 60d does have the flip out lcd screen, which has it's uses. The 60D also has built in video filters, but they're more useful for someone shooting consumer level work.. The 7d firmware has so far proven uncrackable for magic lantern, so if you want to record leveled in-camera audio then stay away from 7d, however most people record on digital recorders anyway.
Between the two I chose the 7d and it's been wonderful so far, though you don't want to have it in direct sunlight since the card overheats and you can only shoot in 12 minute clips. Thankyou Great Britain for that. I've also found that when shooting in very cold weather it shuts off until I heat up the battery a little.
If the 7d/60d is going to be your only camera for video production, I advise thinking about it carefully. They're beautiful cameras, but have many hang-ups.
#6 gavrosh haxhihyseni
gavrosh haxhihyseni
  • 16 posts
  • Albania
Posted 25 May 2011 - 04:47 PM
hello!
I was looking for the first time D60,wandering about the great PQ.
I tried to use the NIKON 50 mm (1:1.7) on it which is a very good lens,but I saw that time after time the light going into decreased for a fraction of seconds than it became normal.Is this because Nikon is an old type?Or I must adjust something in the menu?
Goshi
#7 Phil Rhodes
  • 12167 posts
Posted 25 May 2011 - 05:27 PM
The difference - as a video camera, not a hell of a lot. Maybe some more ISO ratings on the 7, which are probably simulated anyway. 7D has better build quality, takes CF cards rather than SD. 60D has a flip-out monitor, which is nice to have.
I'd buy the 60. The 7 doesn't offer enough more.
#8 Fuzzal Ahmad
Fuzzal Ahmad
  • 2 posts
Posted 26 May 2011 - 04:41 AM
60D's slip screen does have a lot of advantages, since with the small size of DSLRs you do tend to fit in uncomfortable places. PQ is similar. But 7D can be pain when shooting outdoors as it heats up way too quickly. I found 60D to be far more heat resistant.
#9 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 26 May 2011 - 06:06 AM
My personal preference is the 7D for its more professional operating features but the 60D is an excellent camera if you're on a budget.
If you're shooting for hire, you may find Producers want 5D and 7D's just because they're familiar with those models and have used them before.
#10 Fuzzal Ahmad
Fuzzal Ahmad
  • 2 posts
Posted 26 May 2011 - 08:30 AM
#11 Martin Grondein
Martin Grondein
  • 2 posts
Posted 12 June 2011 - 07:37 PM
Go for the 7D if you want film + photography, else the 60D for just film will do.
#12 Robert Li
Robert Li
Posted 12 June 2011 - 08:13 PM
if you are talking about doing film on it its basicaly personal preference, the difference in processors is negligable and the casing and screen are the only diff.
7D casing is magnesium alloy, so, its quite a bit stronger than the 60d in that dept, which is plastic (http://asia.cnet.com...ct-62112267.htm)
the articulated screen on a 60d is useful in odd angle circumstances.
they use different memory cards so maybe, if you already have some CF cards (or SD cards) it would be cheaper than getting another type of memory card (thats the only reason why i chose the 7D).
Otherwise, video is pretty much the same, and they both have heat issues (hey... what hdslr wouldnt)
#13 Matt Stevens
Matt Stevens
  • 705 posts
Posted 20 June 2011 - 12:53 PM
I'm going to move to SE Asia and am going for a 60D simply because of the heat issues that bother the 7D.
#14 Carl Weston
Carl Weston
  • 46 posts
  • New York City
Posted 20 June 2011 - 01:48 PM
as far as video quality is concerned there is no difference between the 7D and the 60D..the extra processing the 7d has is for stills.
#15 Martin Hong
Martin Hong
  • 137 posts
Posted 26 July 2011 - 12:55 AM
Hey there, I've seen that many other users have given their feedback.. So i will give mine in a short summary
If you got enough money you should get 7D.
Reason, the extra money you are paying for are:
Better body construction, magnesium alloy and weather sealing. Although 60D has weather sealing too, just not as complete as 7D's
Dual image processor - 60D has only one
Better viewfinder - 100% coverage.
Uses CF memory card
And the rest are just not that important i think, 60D has the vari-angle LCD and it has 1,02 million dots v.s. 7D's LCD (960k dots)
60D has built-in effects (not very useful for professional use i think)
Otherwise, many professional would choose 7D over 60D for many reasons. Although I'm going to get 60D soon because the economic reason.
But, if you are patient enough, i think canon 5D markIII is on the way.
