First-time with a film camera, is my stock going to be fogged?
#1 Benjamin Lawrence Horace Moyer
  • 2 posts
Posted 08 April 2011 - 12:01 PM
Hello, my name is Ben. I've always been interested in film, and this is the first time I've got up the courage to shoot on film stock and purchase a 16mm camera. I picked up a 1963 16mm Bolex H-16 REX online for $72.
I also picked up some old, but sealed, Primetime 640T and Plus-X 7321 that had been refrigerated by the owner ever since he purchased it around 1996. Should I expect to have fogged film? Are these stocks any good? Does anybody have any experience with either stock? (I'm most interested in hearing about the Primetime.) I am aware that the Primetime is meant only for telecine, that's fine. All I plan to do is have the film developed and telecined.
I am also concerned about getting a dead on exposure. I have a decent incident light meter that has a calibration constant of 330. The Bolex has a shutter angle of 145 degrees. I am going to start shooting at 12 FPS to stretch my dollar on my first reels. This being said, I've calculated that in order to get a decent exposure I should use this equation (where y is the correct f-stop, x is the film speed, and z is the lux falling on the subject.) Does that seem correct? How forgiving is film stock in terms of exposure? Any advice for a nervous begginner would be helpful.
Thanks for your time,
Benjamin Moyer
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 08 April 2011 - 03:31 PM
Benjamin Moyer
The film is junk, being 25 years old.
Light meters have very simple instructions, or just google Sunny F16 rule. Film is very forgiving but always overexpose negative 1/2 stop if in doubt.
#3 K Borowski
K Borowski
  • 3905 posts
Posted 08 April 2011 - 07:16 PM
If you're in the United States, I'd be happy to run some free clip tests for you. . .
Just pay for one-way shipping and I'll e-mail you back the base + fog density. . .
Pretty sure the Primetime is junk though. It was, from what I've heard junk NEW. Grain like cannonballs. Then agian, it lacks the orange base mask, so I don't know where the base fog would compare with a normally-masked ECN-2 film. . .
Private Message me for more details if you're interested. I'm running a lot of clip tests myself in the coming week, so I can piggy back your film onto one of my runs.
#4 Benjamin Lawrence Horace Moyer
  • 2 posts
Posted 09 April 2011 - 09:58 AM
Thanks for the info. As far as the light meter goes, I plan on taking a simple but decent lux meter and wiring it into a TI-84 in order to achieve a more accurate exposure using the equation above. Would that equation work for the programmed "back-end" of the meter software? The "z" value would be determined using the same curve (voltage vs. lux) the manufacturer used, but on the calculator, thus giving the TI-84 the same exact reading as the lux meter would have come up with itself, but without the need to punch it into the calculator manually. Then, using the equation I have outlined above, an f/stop value can be automatically determined by the calculator. This would allow me to use a cheaper lux meter, and would give me greater control over the variables at my disposal. If I am not mistaken, there are four variables available to a film-maker when calculating exposure: lighting, stock (specifically stock speed), exposure time, and the f/stop of the lens. Since the f/stop is the easiest to modify, it would make the most sense to use the other three variables to determine the best possible value for the f/stop. Since film speed and exposure time would remain constant, I could use the calculator to create a simple relationship between the f/stop and the light falling on the scene. I have the physical and electrical aspects of this DIY light-meter project under control, its the equation for a nice "medium-tone" exposure that I am most worried about. How many decimal places should I carry the f/stop number out to? How much of a change in the f/stop value will cause noticeable changes in the final product?
#5 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 10 April 2011 - 03:00 AM
Negative has a huge latitude, more than a stop, you should do some tests to see what works for you. It's not rocket science I can guess the exposure within 1/2 stop. An incident reading with a Lux meter is more than enough.
