How can I hang a Kino Flo from the ceiling?
13 replies to this topic
#1 Jonas Fischer
Jonas Fischer
  • 19 posts
  • Zurich, Switzerland
Posted 17 April 2011 - 03:16 PM
Hello everyone
I'm the DP at a shoot next week, and in on scene in a small office, I want to hang a Kino Flo (4ft 4bank) over a table. In the close up's, we will do it with a Stand, but for the wide shots this will not work,
because the room is very small and it would be in the shot. A wallbreaker will not work too because of the windows on one side. The height of the room is standard (about 9 feet).
Will I be able to tape it to the ceiling or is it too heavy?
Thanks for your help
Jonas
#2 Tim Gill
Tim Gill
  • 8 posts
  • Savannah, GA
Posted 17 April 2011 - 03:24 PM
You could try taking the bulbs out.
Tim Gill
#3 Brian Dzyak
Brian Dzyak
  • 1517 posts
  • Encino, California USA
Posted 17 April 2011 - 04:27 PM
Hello everyone
Jonas
http://www.filmtools...tscisclamw.html
Or you could hide it ABOVE the drop ceiling, letting the light through, if your shot shows the ceiling.
I had to use this very clamp last week to hang a backlight. :)
#4 Nathan Blair
Nathan Blair
  • 62 posts
Posted 17 April 2011 - 07:58 PM
Drop ceiling scissor clamp is probably your best approach. When short on scissor clamps, I've also used Cartolini and Maffers claps to achieve the same effect. If you need it to be higher and there are removable ceiling tiles, you can even hide the light above the ceiling. There's usually quite a lot of space to rig up there unless its taken up by an AC vent or pipe or something.
With any overhead rigging, be sure to use safety cable!
#5 Mike Lary
Mike Lary
  • 472 posts
Posted 18 April 2011 - 01:12 AM
I agree on hanging it above the drop ceiling tiles if possible. Then you can make it nice and safe by clamping to solid structures.
You definitely cannot tape a kino to the ceiling, but you can tape the bulbs if they're removed from the unit.
#6 Mike Lary
Mike Lary
  • 472 posts
Posted 18 April 2011 - 01:20 AM
But I wouldn't trust tape alone on ceiling tiles.
#7 Jonas Fischer
Jonas Fischer
  • 19 posts
Posted 18 April 2011 - 03:22 PM
Thanks for the advice everyone!
But well.. it simply has no drop ceiling.
It's just a normal flat ceiling, without anything to attach anything to.
But I'll probably go with the 'take the bulbs out' method.
Thanks again for the help
Jonas
#8 Adrian Sierkowski
  • 7373 posts
Posted 18 April 2011 - 03:53 PM
There are also gromets you can drill into the ceiling if you want the reflector and all. You'd then have to patch the holes over, but not that hard.
(from http://kinoflo.com/L...lo/Foto-Flo.htm)
#9 Ronald Gerald Smith
Ronald Gerald Smith
  • 72 posts
  • NYC
Posted 18 April 2011 - 08:28 PM
For some information by Roger Deakins about Kinos and the rigging of Kinos, read the following:
Deakins also tapes up bulbs and sometimes he tapes the bare bulb on a foamcore. This is smart because it acts almost like a reflector but soft.
http://www.deakinson....php?f=1&t=1610
#10 Matt Hingstman
Matt Hingstman
  • 7 posts
  • Grip
Posted 25 April 2011 - 11:26 PM
Sounds like you aren't working with drop ceilings, correct? Because if you are, you could rig to a scissor clamp and grip head, or (carefully) bite to something above the panels.
But if you've got a regular ceiling, I can think of two options:
Most Kino units have little gold eyelets for screwing into ceilings. If the place you're shooting at will let you put holes in their walls, this is a solid option. Be sure to screw into as many set of beams as you can and use dry-wall anchors where you can't. Test the weight before you put actors underneath.
The other way is to remove the guts from the backing and tape it. Take out all the bulbs and header cable and use paper tape (perhaps on each individual bulb) to keep them up. To control spill, take some duvateen and tape it in a rectangular shape around the bulbs, creating a skirt.
And if neither of those works, use china balls!
Let us know how it goes!
EDIT - And somehow I missed that there are already a million replies to this thread. My work here is done.
Edited by Matt Hingstman, 25 April 2011 - 11:29 PM.
#11 Michael Dunn
Michael Dunn
  • 4 posts
Posted 28 April 2011 - 05:27 PM
How big is the room? I'm thinking if you can't drill into the ceilings, you might be able to work with the walls and create a four corner support structure--essentially your own overhead rig. I did a similar thing about a year ago in a room that was about 20 feet by 20 feet and it worked great, very solid. The shot was wide but not wide enough to see the corners of the room so it was perfect for that application.
#12 Alex March
Alex March
  • 13 posts
Posted 30 April 2011 - 01:09 AM
Hello everyone
Jonas
what exact effect u wanna archive? soft, harsh backlight or something else? why dont u try to hang a reflector on and a redhead with snoot on the floor instead of a kino (4x4)? Just another idea i did before and it work pretty cool with my scene.
Edited by Alex March, 30 April 2011 - 01:12 AM.
#13 matthew watts
matthew watts
  • 1 posts
  • Best Boy
Posted 07 May 2011 - 09:36 PM
If it's a drop ceiling, use a scissor clamp. It's a 750 spigot with a scissor assembly that clamps onto the Tbar of the drop ceiling. You attach the clamp, put a grip head on it, and attach your Kino.
http://www.bhphotovi...Clamp_with.html
#14 Jonas Fischer
Jonas Fischer
  • 19 posts
Posted 10 May 2011 - 11:30 AM
Hi all
So we finished the shoot about two weeks ago and this is how i made it.
The guy at the rental house suggested it to me and with some sandbags at the other end, it worked.
Int the image below you can see what it looked like.
Jonas
