Aspect ratio for Super 16mm
10 replies to this topic
#1 Ryan H
Ryan H
  • 6 posts
Posted 26 April 2011 - 01:18 PM
Hi there.
I was wondering if the Arri SR2 is capable of shooting in a 4:3 aspect ratio, as opposed to its native 16:9 ratio. If it is possible, how does one go about shooting in 4:3?
Thanks for any help.
#2 Francesco Bonomo
Francesco Bonomo
  • 366 posts
  • currently in Rome, Italy
Posted 26 April 2011 - 02:18 PM
Actually, if I'm not mistaken, I think the original native ratio of the Sr2 gate was 4:3, but all the cameras I've seen or worked with had been converted to S16. So, I guess, if you manage to find an "unconverted" one, you can shoot "regular" 16mm in 4:3.
#3 Adrian Sierkowski
  • 7373 posts
Posted 26 April 2011 - 02:54 PM
Or if you can lay your hands on an SR3; it's swapable between N16mm (4x3) and S16mm (16x9).
Another option would be to look towards older cameras which are still in good service, such as the SR1, Eclair ACL and Eclair NPR as well as the CP16 which may not have been converted but are still quiet enough for sync sound. I believe Aaton LTR-7's also came in N16mm, though i'm not 100% on that as most all Aatons I've seen have been S16mm.
#4 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 26 April 2011 - 03:10 PM
You just need the appropriate groundglass. 1.33 is inside of 1.66 on a Super-16 camera. They share a common height and only the sides of frame change. It depends on whether the conversion of a particular camera allows for recentering or not for an appropriate groundglass.
#5 Ryan H
Ryan H
  • 6 posts
Posted 27 April 2011 - 12:19 PM
Thanks for the replies guys. Instead of changing the groundglass (which I'm told is expensive), or renting a different camera with a 4:3 aspect ratio, how could I go about shooting 4:3 with the SR2? Anything I can do to the viewfinder or when framing the shot?
Thanks again for the help.
#6 Ryan H
Ryan H
  • 6 posts
Posted 27 April 2011 - 01:45 PM
Or could I just block off the left and right sides of the lens with black wrap or something?
#7 Stuart Brereton
Stuart Brereton
  • 3347 posts
Posted 27 April 2011 - 03:54 PM
As a rough guide, you can use the TV safe markings on the left and right of frame. If you shoot a 4:3 framing guide centered in the 1.66:1 frame, you'll soon get an idea of where your 4:3 frame lines should be.
Don't bother even attempting this. The only place for a hard matte is in the gate. Just shoot the full s16 aperture, and then crop in post.
#8 Patrick Cooper
Patrick Cooper
  • 908 posts
Posted 01 June 2011 - 08:09 PM
I thought that the aspect ratio of Super 16mm was 15:9? Of course close enough to the HD aspect ratio of 16:9 which is very convenient when doing HD trasnfers. Correct me if I'm wrong.
#9 David Mullen ASC
Posted 01 June 2011 - 08:18 PM
If this is for a 16mm contact print, you just need a groundglass with the 4x3 area in the proper position even if the camera is exposing Super-16. If for a video transfer, the side-to-side position doesn't matter, just transfer a 4x3 area though of course a 4x3 groundglass will help you compose for 4x3 extraction consistently.
The 16mm camera aperture is sometimes listed as:
10.26 x 7.49mm = 1.37 : 1
The Super-16 camera aperture is sometimes listed as:
12.52 x 7.41mm = 1.69 : 1
However, I believe there was some variation among manufacturers.
#10 timHealy
timHealy
  • 1262 posts
Posted 21 June 2011 - 10:37 AM
Correct me if I am wrong, but I seem to recall that if one truly wanted to go back to regular 16 on an Super 16 SR 1, 2 or 3, the lens mount had to be flipped 180 degrees, or turned is a better word, to recenter the lens for the proper 1.33 ground glass.
I never got my SR upgraded to Super 16 but I thought that was one of the steps. Of course I may be splitting hairs. Re-centering the lens moves the lens a miniscule amount, but projected may lead to slight deformities in the image. Not that I would be able to tell.
And of course shooting in Super 16 mode while using the 1.33 ground glass gives one a bit of reframing room left and right if need be in digital post. So maybe re-centering is a moot point.
Best
Tim
Edited by timHealy, 21 June 2011 - 10:38 AM.
#11 Dom Jaeger
Dom Jaeger
  • 1730 posts
  • Melbourne, Australia
Posted 21 June 2011 - 10:15 PM
Unless it's for a contact print a S16 ground glass with 1.33 markings is all you need, the framed area can be extracted in post. Most established rental houses would have such a ground glass, perhaps as a combo with 1.66 or 1.78. There are ways of marking an SR ground glass yourself using non-residue contact adhesive, but it's fiddly and may not be accurate.
If a print is needed, the best option is to re-centre the mount to Standard and use a Standard 16 ground glass with 1.33 markings. Some early Super 16 SRs had fixed mounts, but most are dual - you simply remove the mount and turn it 180 degrees (and move the locating pin back to top right). It's a good idea to have the flange depth and flatness checked afterwards, though.
If a print is needed, but converting the camera back to Standard is impractical, it is possible to keep the camera in Super but frame with a Standard 16 1.33 ground glass. The only issue is that the lenses will not be centred to the image area - wide angle distortions will be offset and zooms will track off to one side.
