What to Shoot for E-6 Clip Tests?
#1 K Borowski
K Borowski
  • 3905 posts
Posted 26 April 2011 - 11:00 PM
I've inherited a bunch of dubiously stored color reversal film.
Just measuring D-max (blank film) doesn't help.
Normally I'd shoot a grey card, blank film and D-max (min in this case), but I know that reversal sensis have toe density measured in addition to LD, HD MD? (Zone V - 18% grey) and the min, max.
So what zones should I shoot? I know it's -3-1/2 + 3-1/2 for B&W neg. Do I need to make my exposures closer together, owing to the more limited latitude of reversal? I'm as out of my element with reversal these days as I am with B&W.
Too much work with color neg., color pos.; too much lab work, not enough set work :-/
#2 James Compton
James Compton
  • 316 posts
Posted 27 April 2011 - 10:41 AM
Karl,
Is the E-6 film in question, Ektachrome 100D? If so, load some KODAK 100VS into your 35mm SLR for cheap tests that will
bring your into the range you will be shooting in with your mopic camera. Your exposure baseline might be 1/3 under if you want the added color saturation.
#3 Charles MacDonald
Charles MacDonald
  • 1157 posts
  • Stittsville Ontario Canada
Posted 27 April 2011 - 12:10 PM
To be sure you probably could use a grey scale. If it is 35mm E-6 Film, you can do many test shots with a 35mm SLR, the modern e-6 runs in standard still e-6 processing. If it is old VNF that does not apply.
#4 K Borowski
K Borowski
  • 3905 posts
Posted 28 April 2011 - 10:18 AM
No it is 16.
I'm worried about chart sizes. Want to test the actual film out, not a different emulsion.
I'm going to have to shoot everything full-frame or thereabout just to measure it. . .
