2K or HD telecine?
#1 Donald Riley
Donald Riley
  • 20 posts
Posted 28 April 2011 - 04:02 AM
Would 2k compressed to H.264 produce a better picture than 1080p compressed to H.264? Is 2K telecine only used for film prints and digital projectors?
#2 Brian Drysdale
  • 5198 posts
Posted 28 April 2011 - 07:24 AM
2k is the theatrical format you won't see any real quality difference, it will just be wider - 2048 pixels as against 1,920 pixels, giving a different aspect ratio (more or less 1.85). It really depends if you're going for a theatrical distribution, even then many films are shot 1920 x 1080.
#3 John Sprung
John Sprung
  • 4635 posts
Posted 28 April 2011 - 12:25 PM
It'll be very close. With 1920 wide instead of 2048, if you compress both into the same data rate, you'd have a little less compression. That's the trick of original HDCam tape -- they filtered down to 1440 across in order to compress it less.
#4 Will Montgomery
Will Montgomery
  • 2072 posts
  • Dallas, TX
Posted 28 April 2011 - 10:56 PM
There are many more important variables that go into the compression than a few extra pixels to start with. For instance noise & grain levels effect compression much more.
The real advantage to a 2K scan is that you'll get the full frame and you can crop without a resolution penalty. 2K scans of 4-perf 35mm are 2048x1556 and generally these days we crop down to 16:9.
