35mm to 2:35
#1 Shane Martin Smith
Shane Martin Smith
  • 11 posts
  • Orlando, Fl
Posted 08 May 2011 - 02:17 AM
What would I have to do, to shoot 35mm @ 2:35 aspect ratio, on a Arri Lite & Arri Studio camera?
Would it be as simple as changing the ground glass, or is it more complicated?
#2 Fred Neilsen
Fred Neilsen
  • 82 posts
  • Sydney, Australia
Posted 08 May 2011 - 02:43 AM
The rental house should be able to configure it for you, just ask for 3 perf super 35 with the 2.35:1 ground glass.
That being said, 3 perf s35 is boring... have you considered anamorphic or 2 perf?
#3 David Mullen ASC
  • 20069 posts
Posted 08 May 2011 - 01:19 PM
Why is 3-perf 2.35 boring but 2-perf 2.35 isn't???
#4 Shane Martin Smith
Shane Martin Smith
  • 11 posts
  • Orlando, Fl
Posted 08 May 2011 - 03:23 PM
So as far as camera is concerned, I would only have to change the ground glass?
Then I could take 2:35 out of 4 perf 35mm, but it would be cheaper and make more sense to take it from 2 & 3 perf?
Which makes sense, because I read that with 2 Perf, you save nearly 25% of money & film in the end?
#5 Francesco Bonomo
Francesco Bonomo
  • 366 posts
  • currently in Rome, Italy
Posted 08 May 2011 - 03:26 PM
I was about to ask the same thing...besides, how can a format be "boring"?
#6 David Mullen ASC
  • 20069 posts
Posted 08 May 2011 - 06:05 PM
Shooting a 2-perf tall frame means that you shoot half as much film as with 4-perf. Yes, it's a great cost-saver if you can find a 2-perf camera to rent.
The 4-perf 35mm Full Aperture is 1.33 : 1, so the 2-perf 35mm Full Aperture is naturally 2.66 : 1. 3-perf is about 1.78 : 1. You can frame any of them for extracting a 2.40 frame but obviously you waste the most negative if using 4-perf... Unless you shoot with anamorphic lenses.
#7 Shane Martin Smith
Shane Martin Smith
  • 11 posts
  • Orlando, Fl
Posted 08 May 2011 - 06:13 PM
Okay, that really cleared up my confusion. I appreciate your time & wisdom good sir.
Thanks David...
#8 Will Montgomery
Will Montgomery
  • 2069 posts
  • Dallas, TX
Posted 13 May 2011 - 10:02 AM
Keep in mind that 2-perf also leaves zero margin for error in framing or (eeek!) a hair or dust bunny in the gate. 3-perf gives you a little more flexibility in post.
#9 Shane Martin Smith
Shane Martin Smith
  • 11 posts
  • Orlando, Fl
Posted 14 May 2011 - 09:55 PM
Thanks for the note Will.
