Outdoor Lighting. Help
#1 Edison Jia Jun Cheam
  • 2 posts
Posted 09 May 2011 - 01:02 PM
Hello guys. It is my first post in the forum. I need some advice/tips on a current film project I am working on.
I am using the 16mm Arriflex SR3 with a 250T film stock.
The scene is film outdoors, so I think I will shooting using a 85b filter as well.
Shot description: A close up of a woman with a holy effect(her head is heavily back lighted, which will 'portray' her like a saviour, i still want a fairly good exposure on her face, as long as I can see some facial details it would be okay).
The concern that I have is, the difference in exposure is too great such that her face will not be exposed or the natural lighting will be over exposed.
I am seeking for advice or suggestions on whether there is a need for concern and how do I achieve my shot?
Thank you so much for your kind attention. :)
#2 Brian Drysdale
  • 5197 posts
Posted 10 May 2011 - 03:55 AM
Depending on the framing, you could rig a backlight using either a HMI or a CTB gelled tungsten. The back light won't affect the exposure on the face since it won't be illuminating the face, only the back of the head.
#3 jun keung cheung
jun keung cheung
  • 8 posts
Posted 31 May 2011 - 06:45 PM
Maybe- use the natural sunlight to backlight and use a mirror to reflect a frontal light on her face- then diffuse that front light with diff- 129/250. or you can do the same if you have lights- a HMI wedged (bounce off poly then diffuse). Or reflect sunlight off poly and back it way back till to get the exposure you want for her frontal- though note ratio between back and front- backlight will only be as dramatic as low as your key is. A bounced bed sheet can also work wonders...
You can over expose by 2-3 stops on back sunlight and it will be fine. Unless of course she is blond...
JC
