5D into a Ki Pro?
#1 Frank DiBugnara
Frank DiBugnara
  • 168 posts
Posted 10 May 2011 - 04:29 PM
Since I had such a good experience with the AF-100 into a Ki-Pro, I'm wondering if anyone has done this with the 5D?
We've known that the weak link in the 5D is the H264 internal recording. Would HDMI into the Ki Pro and cropping out the camera data in the black areas yield a clean 1080 recording in the Ki Pro? The 5D could not be recording, of course, as it switches into SD output as soon is it is recording to its own card internally.
#2 John Sprung
John Sprung
  • 4635 posts
Posted 10 May 2011 - 04:40 PM
Actually, the weak link with the 5D is the 4:1 vertical decimation. That's what kills the resolution and makes it alias.
#3 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 11 May 2011 - 08:52 AM
You cannot get a clean output from the Canon cameras. There is always data information overlaid on the image. You could record it, but so what?
#4 Frank DiBugnara
Frank DiBugnara
  • 168 posts
Posted 11 May 2011 - 04:30 PM
I thought all the overlay information was in the black area on the top and bottom, if I'm not mistaken. I believe there are options to get a clean image out. If that's the case, it would obviously be easy to crop out the top and bottom black areas.
In regards to 4:1 issue, I'm wondering if this is simply in place as a way to take the native resolution of the sensor (by "native" I mean the resolution used in still mode) and down-sample to 1080. If that is the case, then the 5D is delivering a true 1080 signal, right? The sensor is natively much higher resolution than 1080, so it needs to down res somehow. Is the 4:1 issue the way they do it?
#5 Phil Rhodes
  • 12167 posts
Posted 11 May 2011 - 05:04 PM
The down res is very nasty; it causes all kinds of unpleasant artefacts.
The 16:9 area of the image doesn't fill the HDMI output, so you lose resolution again.
It's not worth it. It may be worth it on a Panasonic GH2.
#6 Oliver Christoph Kochs
  • 323 posts
  • Film Loader
  • Germany
Posted 27 May 2011 - 06:54 PM
Switching off all video overlay is implemented in the latest magic lantern firmware hacks. Still not full HD but possible to record to a Kipro or whatever device while not recording to the cameras CF card.
#7 Vincent Sweeney
Vincent Sweeney
  • 686 posts
  • LA at the moment.
Posted 28 May 2011 - 12:03 AM
Why use these toy cameras anymore? This is why the F3 was built.
#8 David Mullen ASC
  • 20073 posts
Posted 28 May 2011 - 12:05 AM
Err... maybe because the F3 costs 5X what a 5D costs?
#9 Marcus Joseph
Marcus Joseph
  • 404 posts
  • Sydney, Australia
Posted 28 May 2011 - 12:30 AM
Hmm yeah, there are lower end Sony and Panasonic cameras with great functionality and sensor size that are going around close to the 5D, but the data rate is still significantly low and with similar compression. I guess this is the camera manufacturer's trying to create a fine line between professional and amateur productions.
Edited by Marcus Joseph, 28 May 2011 - 12:31 AM.
