max8, super duper8, whatever you call it...
#1 kevin jackman
kevin jackman
  • 350 posts
Posted 11 May 2011 - 05:30 PM
does anybody know what the specs are to file the gate? is it 13% or 20% more frame area? I keep reading conflicting information.
#2 Rick Palidwor
Rick Palidwor
  • 407 posts
Posted 14 May 2011 - 12:24 PM
We calculated about 13% for our super-duper 8 mod. That's approximate. Some photos here: http://www.friendlyf...uperduper8.html
Rick
#3 kevin jackman
kevin jackman
  • 350 posts
Posted 15 May 2011 - 03:20 AM
Rick
so is that a quarter of a mm or something? how far do you go to do that and have you ever had damage from processing or running through the camera?
#4 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 15 May 2011 - 07:14 AM
Hi Kevin,
If we are talking about a MAX8 conversion of a DS8 camera, you have to bear in mind that it is not feasible to extend all the way to the edge of the film like it is on cartridge super8 because at that point some light would spill over and expose the edge of the B-side of the film. A thin barrier should remain at all times.
Cheers,
Jean-Louis
#5 Andries Molenaar
Andries Molenaar
  • 683 posts
  • Amsterdam
Posted 15 May 2011 - 08:34 AM
There is a border of almost .7 mm which could at max be annexed. The trick is that more of the height can be used as there is less need to crop for a 16:9 So in square mm gain is much better. :)
You can always the option to do nothing and just crop. After all it is just trick the get a slighty better deal from a frame.
BTW Processing doesn't damage the sides or border of your film. If it does get another lab.
