anamorphic on ebay
#1 kevin jackman
kevin jackman
  • 350 posts
Posted 12 May 2011 - 12:22 AM
Im sure the price will go beyond my control, but is this one that people would use?
http://cgi.ebay.com/...atchlink:top:en
#2 Chris Burke
Chris Burke
  • 1726 posts
  • Boston, MA
Posted 12 May 2011 - 09:51 PM
yes this is the type of lens people use, but this one is a bit beat up.
#3 kevin jackman
kevin jackman
  • 350 posts
Posted 12 May 2011 - 10:33 PM
What do you see thats wrong with it?
#4 John Sprung
John Sprung
  • 4635 posts
Posted 13 May 2011 - 12:02 AM
For one thing, it's not in any kind of standard mount.
#5 kevin jackman
kevin jackman
  • 350 posts
Posted 13 May 2011 - 03:17 AM
I could probably get a mount made but the question is, is it the same glass and element arrangement that others are using? Basically Im wondering if it is recognizable. The glass seems fine.
#6 Mark Dunn
Mark Dunn
  • 2670 posts
Posted 13 May 2011 - 05:00 AM
I don't know- look here about halfway down http://captjack.exak...m/Isco page.htm
If that's it, it suggests it's an objective, not an adapter.
Seems it was intended as some sort of trick lens.
That example seems to lack the iris.
It has a rather small protruding rear element, not the large barrel you'd need to attach to a filter ring.
I'm not sure this is an anamorphic adapter at all. I certainly wouldn't gamble much money on it when there are plenty of proper ones on eBay.
#7 John Sprung
John Sprung
  • 4635 posts
Posted 13 May 2011 - 11:20 AM
OK, thing #2: It's just a 50mm. Are you going to shoot a whole show on a 50? Odds on finding the rest of a matching set are nil.
#8 kevin jackman
kevin jackman
  • 350 posts
Posted 13 May 2011 - 12:09 PM
that was another consideration. so when you get something like a bolex anamorphot, there is no so called focal length to it, its just something you add to the lens you are using?
#9 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 16 May 2011 - 05:40 PM
But this is also an attachment. It would have originally came with a 50mm still lens, probably with a Nikon mount.
If it covers a 50mm 24x36mm format lens it will cover a16mm 16R lens.
The problem is building a bracket for attaching the lens to the camera.
