Monitor Suggestion for 5D MK II
11 replies to this topic
#1 David Kappler
David Kappler
  • 6 posts
  • Philadelphia
Posted 26 May 2011 - 08:53 PM
I need to get an external monitor for my 5D. I'm not so sure that a $1800 Marshall is warrantd here. I just need to use it to compose, adjust exposure and focus. Does anyone have any suggestions?
#2 Jaron Berman
Jaron Berman
  • 184 posts
  • New York, NY
Posted 26 May 2011 - 09:29 PM
the $500 marshall 5.6" is pretty common, and takes AA's. it's handy when you must shoot 5d
#3 Kieran Scannell
Kieran Scannell
  • 339 posts
  • Netherlands/Ireland
Posted 27 May 2011 - 12:16 PM
http://www.cinema5d....ag=cineroid-evf
This is the best little EVF I've used so far. Has a loop through function for 2nd LCD for focus puller or director. But the 5D changes monitor resolution in record mode so I don't know
if the cineroid would have issues with that, have to check!
#4 Jean Dodge
Jean Dodge
  • 110 posts
Posted 07 June 2011 - 02:01 PM
The Liliput and Ikans are popular over at cinema5D forum - look there for better advice. Many many issues arise about splitting an HDMI signal, so dont expect to have a director's monitor or client monitor for cheap.
#5 Martin Hong
Martin Hong
  • 137 posts
Posted 30 July 2011 - 01:40 AM
Not long ago Sony released an external monitor
http://www.bhphotovi...CD_Monitor.html
5" 800x480 LCD display, runs on Sony's battery. Not sure what size you are looking for, but this one is compact and nice, and is not that expensive..
#6 Phil Rhodes
  • 12175 posts
Posted 30 July 2011 - 07:38 AM
Grab yourself a 24" TFT of some kind. Check it'll accept the rates the 5D will do, and you're good. Huge, of course, but that has its upsides too. At some point, if you need to see it, you need to see it.
And you can watch TV on it.
#7 Colin McQuillan
Colin McQuillan
  • 7 posts
Posted 10 August 2011 - 11:55 PM
SmallHD DP6 has worked great for me. Fantastic little monitor.
http://www.smallhd.c...oducts/DP6.html
#8 bogdanovici barbu
bogdanovici barbu
  • 26 posts
Posted 20 August 2011 - 05:48 AM
i agree with Collin, smallHD is a nice little gadget and dosen't cost as much as the marshal monitor.
#9 clyde villegas
clyde villegas
  • 44 posts
Posted 07 September 2011 - 07:07 AM
Sorry for this newbee question, but how do you do critical focus with an external monitor? The resolution out of the HDMI port is SD. Thanks and God bless!
#10 Colin McQuillan
Colin McQuillan
  • 7 posts
Posted 13 September 2011 - 11:28 PM
I believe the HDMI port on the 5D is 1080 until you hit record - then it scales down to SD - so if you are planning shots rather than run/gun, check focus before you roll.
Also, most small format HDMI monitors are only pumping out about 800x600.
#11 clyde villegas
clyde villegas
  • 44 posts
Posted 14 September 2011 - 04:52 AM
Yes, I've also heard that it's 1080 until you hit record.
I can plan the shot, mark the follow focus, and shoot the scene. If the subject walks toward the camera, I can check focus in the starting point and ending point where he stops walking. This means that I will have sharp focus at those two points. But how about in between those markers while the subject is walking, how do you get critical focus on that? Is it mere luck? Thanks and God bless!
#12 Phil Rhodes
  • 12175 posts
Posted 14 September 2011 - 05:59 AM
Well, skill, which is sort of like reliable luck.
