I have an important question :
Do I need to use flicker free HMI ballasts when shooting with the Alexa at 24 fps? 23,97?
Does it work like the RED, with a rolling shutter that can make some lines moving through the frame?
Thanks!
HMI + Alexa
Started by
Marie Davignon
, Jun 16 2011 04:49 PM
#1
Posted 16 June 2011 - 04:49 PM
#2
Posted 16 June 2011 - 04:57 PM
I haven't had problems with older HMI's on either the Red or Alexa. Yes, the Alexa has CMOS sensor with a rolling shutter.
At 23.98 fps, you are on the edge of flicker but usually it's not noticeable unless you look at a waveform monitor.
#3
Posted 19 June 2011 - 12:20 PM
Thanks!
#4
Posted 19 June 2011 - 02:09 PM
I have seen a 60Hz HMI flicker on a 7D at 1/60 shutter.
There appear to be no rules.
#5
Posted 28 June 2011 - 03:03 PM
Its always safer to shoot flicker free. You should be able to see any issues on the waveform however. Sometimes it will only show up from 1 light or at a particular angle depending on conditions as a very slow pulsing density shift.
Flicker free will make sure however of no issues at 23.98
Beware fluorescents in locations with magnetic ballasts however.
Thanks!
