Tobin Cinema Systems + Bolex MM Motor Cable
#1 Fernando de la Rosa
Fernando de la Rosa
Posted 29 June 2011 - 12:16 PM
Greetings
I recently bought a tobin crystal sync unit for my h16 SBM, and have been looking for the cable that connects this unt with the 400 ft magazine MM motor.
I tried chambless cine eq. but they re out of stock.
Does anybody have one for sale?
Any clue on where could i find one please?
#2 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 29 June 2011 - 12:38 PM
What kind of connector is used for the mag connection?
Cheers,
Jean-Louis
#3 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 29 June 2011 - 01:26 PM
Found one here:
http://www.nakanocam...10-bcrysta.html
Is this the one you have?
I could make you a cable based on the instructions for this motor.
http://www.tobincine..._PDF/TXM10B.pdf
Tobin used to charge $49 for a cable. I can do it for a little less.
Cheers,
Jean-Louis
#4 Fernando de la Rosa
Fernando de la Rosa
Posted 29 June 2011 - 02:42 PM
Jean Louis:
I apreciate your atention.
I bought a TXM 20B unit, the kind that takes a jack to 4pin XLR connection.
Is it possible to adapt the MM cable to the sync unit's source?
Best regards ;)
#5 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 29 June 2011 - 05:09 PM
From the TXM20B manual, it would seem you just need to convert your two pronged connector to a 5.95mm x 2.1mm locking inverted power plug or a standard 5.5mm x 2.1mm inverted power plug.
Cheers,
Jean-Louis
#6 Fernando de la Rosa
Fernando de la Rosa
Posted 01 July 2011 - 05:20 PM
Hi Jean Louis
Id like to thank you for your prompt help on this subject.
Ill see if i can get the right plug to solder to the MM cable on the local electronics shop.
Once again, thanks a lot!
Best,
Fernando
