Arri 2b vs Arri BL2 for HD Music Video
#1 Gary Robinson
Gary Robinson
  • 54 posts
Posted 08 July 2011 - 02:23 PM
Hi Guys,
I have an Arri BL2 and an Arri 2b (with way more mags and easier to shoot with). If I'm transferring the 35mm footage to HD, how big of quality difference will I see after the transfer with the BL2 vs 2B? Looking at a previous film, the 2B has borders between the frames while the BL2 is almost solid images with just a very small line between the frames. I"m using the same lens on both.
Gary Robinson
www.sharpcut.com
Edited by Gary Robinson, 08 July 2011 - 02:26 PM.
#2 John Sprung
John Sprung
  • 4635 posts
Posted 08 July 2011 - 03:59 PM
The biggest factor is how well maintained and adjusted they both are. A tuned-up II-B will way outperform a thrashed BL.
But assuming they're in equally OK shape, the BL has pin registration, so should be somewhat steadier. If this is only for video, that won't matter much. Of course, the BL is significantly quieter, but you knew that already. Given that you own them both, bring them both.
#3 Gary Robinson
Gary Robinson
  • 54 posts
Posted 08 July 2011 - 05:11 PM
Thanks John,
Because the Arri 2B captures a smaller image, when cropped for 16x9 will it look much grainier?
Gary Robinson
www.sharpcut.com
#4 Dom Jaeger
Dom Jaeger
  • 1745 posts
  • Melbourne, Australia
Posted 08 July 2011 - 10:49 PM
No, you'll be cropping the frame height to get 16x9 anyway. As long as the width is the same, a slight difference in the original frame height is irrelevant.
#5 John Sprung
John Sprung
  • 4635 posts
Posted 11 July 2011 - 05:20 PM
The Arri I, II-A and II-B were all Academy aperture. The BL could be either Super or Academy. The difference in grain pattern will be quite small, but definitely there. It's a matter of taste, you really have to shoot tests and decide. Or, cheaper, just take an existing piece of Super-35 and telecine both full width and academy crops to compare.
