Matte box and Filter buying advice
#1 Deji Joseph
Deji Joseph
  • 109 posts
Posted 26 August 2011 - 05:41 AM
How do I choose which factors to look for when buying a matte box and filters and any suggested buys?
Dj
#2 Shelly Johnson ASC
Shelly Johnson ASC
  • 34 posts
  • California
Posted 28 August 2011 - 01:02 AM
Dj
Hi Deejay,
When I first started buying my filters, I got some great advice. Mainly to get a complete set of 85-ND combos (that was for film... if you shoot mostly digital then maybe just a complete set of ND's), a POLA and a set of Hard Edge and Soft Edge ND grads. That was what I started with. I eventually started buying unique diffusion filters as they came about... but only in the intensities that I used... 81EF-ND's and POLA-Combos (although... again with digital, you can simplify here) and certain color grads that I use. The set grows through the years until you have more filters than you can count.
I tended to buy my correction and ND filters in Panavision 4x5.65 size, the POLA's in 138mm Round and the Grads in 6x6. I can pretty much make that work on any Matte Box and lens (with rented adapter trays if needed). There are times when the 4x5.65 size get a bit small on certain gigantic lenses, so I just rent certain filters when necessary to get the coverage I need. Having an entire set in 6x6 or both 6x6 and 4x5 would get a bit unwieldy. Although, for a while, Tiffen had a 5x6 size that was very versatile. Not sure if that size exists anymore.
Acquiring filters is a great way to start a collection and at the same time customize your photographic preferences. Also, the rental mark-up on filters is very good. They pay for themselves rather quickly... then filters begin to pay for more filters... if you follow my meaning!
#3 Zach Quatronostro
Zach Quatronostro
  • 2 posts
Posted 31 August 2011 - 02:58 PM
Dj
Well, mountability and compatibility should be a pretty big factor. I found this cool little DSLR right that lets you mount a matte box and follow focus for pretty cheap: http://www.habbycam....age_rod_kit.htm
#4 Deji Joseph
Deji Joseph
  • 109 posts
Posted 31 August 2011 - 04:17 PM
Thanks zach, I already have a rail setup though.
Dj
