Technical Details EUMIG C 16
#1 Simon Wyss
Simon Wyss
  • 1493 posts
  • Basel, Switzerland
Posted 03 September 2011 - 12:40 PM
Fellows
Here is some knowledge of the Austrian 1956 product.
Opening angle in black plastic shutter: 160 degrees
Rigidly controlled pulldown claw from the front according to ISO 69, leaving film at +3 position
Lateral film guide by spring blade at optical axis height
Main shaft bearing claw cam and shutter as well as governor shaft in miniature ball bearings, these under spring blades
Main shaft steel worm, driving worm gear plastic; grease
Three-blade centrifugal governor, horizontally arranged, leather-covered braking disk against steel arm
If one is to clean and relube the mechanism one has to totally disassemble the camera. No bearing can be lubricated from outside. Brass gears, not ground
The 25mm 1.9 lens has a ten blade double iris diaphragm.
Hope this will help somewhere sometime.
#2 Erkan Umut
Erkan Umut
  • 215 posts
  • Istanbul
Posted 11 July 2012 - 08:02 AM
Fellows
Simon,
Great share!
Thank you so much.
Best
#3 Steve Broback
Steve Broback
  • 31 posts
  • Gig Harbor, WA
Posted 12 July 2012 - 06:45 PM
Very useful post - Thanks!
I have several of the C16s and they are getting slow with age (and old grease)and can barely pull film through the gate. They definitely need to be disassembled and lubed.
I have made a PDF of the instruction manual if anyone needs it.
Steve
#4 Erkan Umut
Erkan Umut
  • 215 posts
  • Istanbul
Posted 13 July 2012 - 12:32 AM
Steve
Thank you Steve!
I've downloaded that manual you made on A/City.
