Arri 35 BL4 current consumption
#1 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 09 September 2011 - 08:05 AM
Hi everyone,
Does anyone have the specs for this?
I'm making a battery pack and trying to gauge what is an appropriate capacity for the cells.
Thanks.
Jean-Louis
#2 Tom Jensen
Tom Jensen
  • 1234 posts
  • Dallas, TX
Posted 09 September 2011 - 10:25 AM
Hi everyone,
Thanks.
Jean-Louis
I probably shouldn't answer this because I can't really remember.:lol: I think it's between 2.5-3 amps.
#3 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 09 September 2011 - 11:47 AM
That sound about right. I see that block batteries seem to be used a lot for these cameras and these are around 7Ah to 8Ah which would be a good match. Thanks.
Jean-Louis
#4 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 10 September 2011 - 08:21 AM
Another question:
Can someone confirm if the camera be safely connected to a 13.2V or 14.4V battery source?
Thanks.
Jean-Louis
#5 Tom Jensen
Tom Jensen
  • 1234 posts
  • Dallas, TX
Posted 10 September 2011 - 09:43 AM
Again, my memory ain't great but I'm going to say 14.4.
#6 Dom Jaeger
Dom Jaeger
  • 1725 posts
  • Melbourne, Australia
Posted 11 September 2011 - 11:27 PM
Hi Jean-Louis,
you and Tom seem to have worked it out already, but for what it's worth, I have specs for the BL4s - I think it's pretty similar to a BL4 in terms of current draw.
The camera movement alone should draw 1.8 A.
At 24/25 fps with a 400' load the draw should be 2.5 - 3 A.
Of course, if you're running enough accessories from the camera accessory socket (lens light, heated eyepiece, split, mini-monitor, Preston etc) you can easily double that. I think the supply fuse is 7 amps.
12V 7Ah lead-acid block batteries were pretty standard for these cameras, but if more weight isn't an issue and there are a few accessories to power a 12Ah cell is better.
If you're going with NiCads, you should be OK with 14.4V (we never had a problem). You're definitely fine with 13.2V.
#7 Tom Jensen
Tom Jensen
  • 1234 posts
  • Dallas, TX
Posted 12 September 2011 - 12:55 AM
Lucky guess.
#8 Dom Jaeger
Dom Jaeger
  • 1725 posts
Posted 12 September 2011 - 03:11 AM
Just to clarify, that's the in-camera accessory supply pico fuse, not the battery fuse.
For the battery I'd use a 15 amp fuse - the start-up current can potentially spike above 10 amps.
#9 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 17 September 2011 - 08:40 AM
Thanks to all that replied!
Cheers,
Jean-Louis
