Used ACL, scraping sound.
#1 Derek Van Gorder
Derek Van Gorder
  • 19 posts
Posted 18 September 2011 - 01:35 PM
I acquired a used ACL from ebay. It's definitely a little beat-up, but is in working order.
This is my first 16mm camera, and I'm spending time trying to learn the basics and how to load it properly. I definitely will be getting it properly serviced by a technician before using it on any production.
I ran one trash roll through it. Seems to be working OK, and I don't see any timing problems, but it makes a repeating scraping sound while running. I couldn't quite figure out which part was causing the sound. I recorded a video of it running:
View on Vimeo
(password = eclair)
Any thoughts on what's causing this? Maybe I just haven't loaded it properly? I wanted to shoot a test roll or two before sending it out, but if you think I risk damaging the camera by running it like this, I could just get it serviced right away.
Thanks.
#2 Bernie O'Doherty
Bernie O'Doherty
  • 232 posts
  • Newark Valley, NY
Posted 18 September 2011 - 02:16 PM
Hi Derek,
Sounds like the feed side core adaptor plate is bent. Open up the feed-side door and watch the film in motion. It's probably probably being rubbed by the bent portion of the adaptor plate while in motion.
Could also be the take-up side.
Solution is to patiently unbend the plate by hand. Try flipping the feed-side plate to the take-up side to see if it helps.
Good Luck,
Bernie
#3 Ian Cooper
Ian Cooper
  • 469 posts
  • England
Posted 18 September 2011 - 04:43 PM
Hi Derek,
Good Luck,
Bernie
If that's the case, then if the ACL mag is like the NPR, you can remove the spool adapter plate and put a daylight spool in the magazine instead. If you're able to do that and the noise stops then it confirms the adapter must be what's rubbing.
#4 Derek Van Gorder
Derek Van Gorder
  • 19 posts
Posted 19 September 2011 - 12:23 PM
Thanks, Bernie & Ian! I'll give it a try.
