Loading film with infrared light ?
10 replies to this topic
#1 Philippe Lignieres
Philippe Lignieres
  • 65 posts
Posted 23 September 2011 - 12:51 PM
Hi everybody,
Just as said in the tittle, i was wondering if loading 50' B&H magazines under infrared camera is possible without causing damage to the film ?
B&H magazines are very special and very difficult to load it without looking just a bit...
I poligise for my poor english.
Philippe
#2 John Salim
John Salim
  • 190 posts
  • Essex, UK
Posted 23 September 2011 - 06:19 PM
Absolutely no problem using infra-red monitoring Philippe.
You can use it with any speed panchromatic B&W or colour film...... but not with infra-red film of course !
John S :)
#3 Brian Pritchard
Brian Pritchard
  • 330 posts
  • Rushden UK
Posted 24 September 2011 - 03:48 AM
You do need to be a bit careful in case the IR lamps are giving off any visible light. You could test a short length of a fast B/W stills neg by leaving it under the lamp for a few minutes with a coin placed over the middle of the film and then developing it to see if there is an image of the coin. This is the standard way to test a safelamp in a photographic darkroom.
Brian
#4 Phil Rhodes
  • 12167 posts
Posted 24 September 2011 - 05:07 AM
I'd have thought the issue would be light from the video monitor. What's the plan, do it inside a changing bag with a cable run to the outside world?
Most IR illuminators will be LEDs which very definitely can emit some very deep visible red light.
#5 John Salim
John Salim
  • 190 posts
  • Essex, UK
Posted 24 September 2011 - 05:51 AM
Probably a bit difficult to set up an IR camera inside a changing bag, but you could adapt a 'dark box' ( as used by high street minilabs ), or make one large enough to take a camera or magazine ( you could even use a wireless CCTV camera nowadays ).
IR LED's are very suitable as IR illuminators as they have a narrow peak in the IR region, are quite bright and will never emit visible light.
Personally I use IR goggles in the darkroom :ph34r:
John S
#6 Phil Rhodes
  • 12167 posts
Posted 24 September 2011 - 08:28 AM
This is definitely not true for all types of IR LED. I've seen infra-red emitters for things like auditorium sound systems (for people with hearing problems) in cinemas and theatres emit really quite a lot of very deep red visible light. So, this could be a dangerous assumption.
There are, I believe, near IR and deep IR types, and the choice is clear.
#7 John Salim
John Salim
  • 190 posts
  • Essex, UK
Posted 24 September 2011 - 09:36 AM
As it happens I've seen cinema 'IR' emitters with a deep, dark red light too Phil, so maybe they use different types of LED's ( with a wider bandwidth ) for maximum coverage ?
'Proper' IR LED's start to radiate from 880nm peaking at around 940nm whereas most colour and B&W film will be sensitive up to around 700nm - 750nm.
John S
#8 Jock Blakley
Jock Blakley
  • 73 posts
  • Melbourne, VIC
Posted 24 September 2011 - 09:46 AM
One set-up I once saw used IR-pass filters from still photographic suppliers (may have been Hoya, but a few years have passed now) over the emitters... seemed to work fine.
#9 John Salim
John Salim
  • 190 posts
  • Essex, UK
Posted 24 September 2011 - 01:24 PM
Actually you can use several layers of unexposed and processed reversal film over a lamp to use as an IR light source.
John S
#10 Ron Varga
Ron Varga
  • 8 posts
  • Electrician
  • New York City.
Posted 24 September 2011 - 02:54 PM
Hi everybody,
Philippe
It's alway's best to put into practice loading a mag without using any special lighting equipment. Just practice it till you know it like your toothbrush. Also, you have to ask yourself; "What if I don't have any special light to aid me in loading the magazine?" You have to know your tools.
Edited by vargavision, 24 September 2011 - 02:55 PM.
#11 Philippe Lignieres
Philippe Lignieres
  • 65 posts
Posted 25 September 2011 - 02:57 PM
Thanks everybody for so many answers.
I will try ASAP.
Of course it is better to know how to load a magazine, BUT B&H 50' magazine are VERY special ones, very little and quite uncomfortable to load.
In fact, i have seen a big black charging box with a IR camera in it at a military base where missiles were filmed by high speed cameras. And, of course, somme problems of jamming, I suppose...
But I was wondering if it would be very special military camera, or standard.
So, I will buy a cheap IR led camera, and see what happen...
In case it's easy to do, B&H 50' magazine cameras could be a poor man Ikonoscop...!
