RED EPIC
#1
Posted 27 September 2011 - 06:40 PM
I am shooting some B-roll of a sport event for a commercial on friday night. We will be using the EPIC at 2K, shooting 300fps or maybe 240fps (so we can lower compression). I have read somethings about the 2K being chunky in the blacks with noise. Has anyone experienced this?
Will be shooting with the optiomo 24-290 to give myself a fighting chance under stadium lighting.
Cheers
Andy
#2
Posted 28 September 2011 - 02:27 PM
Hi
Cheers
Andy
From the tests I have done 2K from Epic is better than 2K from Red one, compression did not seem an obvious issue.
#3
Posted 28 September 2011 - 08:27 PM
Was that at High Speed Stephen.From the tests I have done 2K from Epic is better than 2K from Red one, compression did not seem an obvious issue.
#4
Posted 28 September 2011 - 10:07 PM
300 fps, there would be no point to shoot 2k unless high speed is needed.
#5
Posted 28 September 2011 - 10:13 PM
#6
Posted 28 September 2011 - 10:21 PM
I don't agree with that statement, but thanks for the clarification. Some shows here use 2K to get extra focal length from their lens, for instance.
Seems a really bizarre thing to do, there is a resolution hit at 2k. A x2 tele-converter would be a better option.
#7
Posted 17 October 2011 - 01:07 PM
I did a couple of tests at 2K 300 FPS....and I did notice some pretty bad noise in some areas, mostly the blacks. Oddly, with one test shot of someone in extreme sunlight, the image was disgustingly noisy...like it looked like a low quality H264 compression.... And that shot was at 48 fps at 5K....we couldn't really figure out why...the compression rate must have been unusually high for that one shot.
#8
Posted 17 October 2011 - 08:38 PM
I could see how its bizarre if your in a controlled environment. Although in some outdoor situations its awesome. The other day i had a Red 300 and a doubler in my pack. At 4K the 300 wasn't enough to put my subject into in full frame. I switched it over to 2K (600) and it still wasn't enough. Then I put on the doubler at 2K (1200) and the subject was in full frame. You start to loose stops but if your shooting in daylight it doesn't matter. Great way to get crazy Focal DOF on anything as well. Lots of stuff to work with if you have a doubler and the capability of switching from 4 to 2K! It just depends on what you shoot for a living...Seems a really bizarre thing to do, there is a resolution hit at 2k. A x2 tele-converter would be a better option.
Edited by Dustin Lindgren, 17 October 2011 - 08:39 PM.
#9
Posted 18 October 2011 - 10:35 AM
You need to do a black shading before shooting 2k @ 300.
#10
Posted 04 November 2011 - 03:00 PM
~Marque
Want To Shoot A Scarlet...
http://www.indiegogo...?a=32535&i=addr
