Changing audio to "walkie talkie"
#1 Richard Boddington
Richard Boddington
  • 3712 posts
  • Gender:Male
  • Occupation:Director
Posted 19 November 2011 - 09:59 AM
Ok FCP experts how do I re-process some normal sounding audio to make it sound like it's coming over a walkie talkie?
The first person to tell me will be the editor of my next major motion picture. As such you will receive enormous amounts of money, be adored by beautiful women, and have your face licked by a very cute little puppy.
R,
#2 Phil Rhodes
  • 8374 posts
  • Gender:Male
  • Occupation:Other
Posted 19 November 2011 - 11:07 AM
Using only basic filters?
Hmm. Use the equalisation filter to remove both very high and very low frequencies. Use the volume filter to wind it up until it distorts, then wind it back down again. This might not work if you are working in 32 bit audio; you might have to increase it to distortion level, export it to a file, then bring it back in again and make the level sane. Add noise, probably from a library of radio noise sound effects. Add clicks at the start and end of the "transmission".
You could go further with modulation etc. What's the fictional situation?
#3 Richard Boddington
Richard Boddington
  • 3712 posts
  • Gender:Male
Posted 19 November 2011 - 11:33 AM
Voice of a chopper pilot as we track the chopper air-to-air.
All good ideas thanks, I'm on it.
R,
#4 Phil Rhodes
  • 8374 posts
  • Gender:Male
  • Occupation:Other
Posted 19 November 2011 - 12:06 PM
Ponder a bit of modulation then ("warble"). You can do it in Goldwave, which is cheap or nearly free.
Some jet noise in the background, if it's a jet copter. Blades, etc.
#5 Richard Boddington
Richard Boddington
  • 3712 posts
  • Gender:Male
Posted 19 November 2011 - 01:34 PM
Yep got that in and some "garble". Still not as good as what the post house can do, they must have a fancy plug in for this.
Or I record it live through a real walkie talkie, there's always that.
R,
#6 Phil Rhodes
  • 8374 posts
  • Gender:Male
  • Occupation:Other
Posted 19 November 2011 - 04:47 PM
I suspect they've probably got Sound Forge, which is just a pile of normal filters. A lot of it is appropriate recording - some of the sound of radio comms is actually the nasty mic, and the proximity of it to the user's mouth, causing additional distortion and plosives.
#7 Daniel Smith
Daniel Smith
  • 791 posts
  • Gender:Not Telling
  • Occupation:Other
Posted 20 November 2011 - 04:25 AM
Some compression, a little distortion and a bandpass filter at around 3.4Khz (telephone bandwidth). If you want send it over, I have an Audio NLE and can edit it and send it back pretty quick.
