Technique question
7 replies to this topic
#1 Mickey Kafka
Mickey Kafka
  • 7 posts
Posted 20 November 2011 - 08:17 PM
I noticed Wong Kar Wai shot this way in at least a couple movies: blurry motion, at near regular speed. How would you shoot that? Do you set FPS to lower than usual, and then speed up afterwards? Or what else can you do?
This is what I'm referring to:
Posted 20 November 2011 - 08:22 PM
Yes, shot at low frame rates like 6 fps and step-printed back to normal speed. Doing that gives you more strobing because of a lack of motion information and more blurring due to a longer shutter time per frame.
#3 Mickey Kafka
Mickey Kafka
  • 7 posts
Posted 20 November 2011 - 09:01 PM
Thanks, David! I'm glad you gave me that word 'step-printing', I wasn't sure what that was called. It makes sense now.
#4 Patrick Kaplin
Patrick Kaplin
  • 44 posts
  • Ottawa, Canada
Posted 21 November 2011 - 11:42 PM
Anybody know the technique in post for achieving this digitally? I know Slumdog did it shooting on a dslr at 12fps then step printing back I believe. Anybody know the method for achieving this in a standard NLE shooting at a lower frame rate on a RedMX for example? Or when you shoot on a RedMX at a lower frame rate on a 23.98 time base does it achieve this automatically?
#5 jacob thomas
jacob thomas
  • 178 posts
Posted 22 November 2011 - 05:21 AM
I've done this a on the Red at 6fps and with a 7D shooting stills at approx 6-8fps.
The Red treats the low frame rate footage as 'fast motion' and you need to slow it down in post.
Last time I tested FCP, AE, Nuke and Compressor and found the most pleasing results to my eye were simply with the speed control in FCP and frame blending on (which doesn't make any sense from a step printing perspective).
#6 Chris Millar
Chris Millar
  • 1642 posts
Posted 23 November 2011 - 01:58 AM
Maybe AE, FCP, Nuke etc... have options where you select no frame blending and so on - but if you like doing things the hard way though a technique would be to save all the frames as stills then set up a script or something in Photoshop/Applescript ...
Or by hand Posted Image
#7 jacob thomas
jacob thomas
  • 178 posts
Posted 23 November 2011 - 03:03 AM
FCP has the option of frame blending on or off. The point I was trying to make was to me it looks better with it on. :unsure:
I don't think photoshop would be the most efficient way of doing this as iirc all the above software can slow footage down by simply duplicating the frames.
#8 Chris Millar
Chris Millar
  • 1642 posts
Posted 23 November 2011 - 03:16 AM
Sure ...
But this is the look the OP was after - just saying it could actually be done in a pinch with nothing more than applescript and quicktime (or your windows/linux variants).
A terminal script for those able to poke about in there
