Approx. 36 fps - Canon 1014XL-S & 814XL-S
#1 Erkan Umut
Erkan Umut
  • 215 posts
  • Istanbul
Posted 30 November 2011 - 06:14 PM
Why its an approximate value? Why not exact?
Because of battery drainage?
Thanks for any reply.
#2 Matt Stevens
Matt Stevens
  • 705 posts
Posted 30 November 2011 - 08:43 PM
No super8 can give you exact frames per second. They just are not built with that kind of precision. If you spend some money, you can crystal sync the 1014 XL-S for 24 fps and get sync sound...
http://www.webtfg.com/sync8.htm
#3 Andries Molenaar
Andries Molenaar
  • 683 posts
  • Amsterdam
Posted 01 December 2011 - 03:10 AM
Probably the slow-motion function works by disengaging the speed regulator and applying full voltage to the motor. Then it is unregulated and it is only a best guess :) It would indeed be dependend on the condition of the batteries.
The Canon are known to be spot on with their standard fps. I.e. on a full length of a cartridge (3000-4000 frames) the would only be off by 1 frame. Very suitable for sound-syncing without spending thousands :) But you would need to test the accuracy.
Edited by Andries Molenaar, 01 December 2011 - 03:11 AM.
#4 Erkan Umut
Erkan Umut
  • 215 posts
  • Istanbul
Posted 01 December 2011 - 03:33 AM
Thank you Matt!
Its not about X-tal sync or pulse sync, etc.
I just would like to know, why Canon gives this approx value for 36fps.
I've never seen approx values given of slo-mo fps rates for any other camera than these two models.
#5 Erkan Umut
Erkan Umut
  • 215 posts
  • Istanbul
Posted 01 December 2011 - 03:42 AM
Thank you Andries!
I just would like to know, why Canon gives this approx value for 36fps on all Canon literature.
For an example, I have a Nikon R10, and the 54fps exact value is given on all Nikon literature.
Edited by Erkan Umut, 01 December 2011 - 03:43 AM.
#6 Matt Stevens
Matt Stevens
  • 705 posts
Posted 01 December 2011 - 10:04 AM
I had two R10's and that spec isn't exact. No doubt. But it's fairly close from the slow mo tests i performed.
GREAT camera.
#7 Erkan Umut
Erkan Umut
  • 215 posts
  • Istanbul
Posted 01 December 2011 - 04:18 PM
GREAT camera.
So, Canon gives the fair specification of slo-mo fps rate for these cameras.
#8 Andries Molenaar
Andries Molenaar
  • 683 posts
  • Amsterdam
Posted 01 December 2011 - 05:11 PM
Thank you Andries!
They can print what they specified it to be and what they tried to adjust the regulator for.
But if there is an unregulated speed then they can only print aproximate :)
It is more a linguistic problem rather then a speed problem.
#9 Erkan Umut
Erkan Umut
  • 215 posts
  • Istanbul
Posted 01 December 2011 - 05:14 PM
Posted Image Liked that reply very much! GREAT!
