Canon 5D MkII SD Anamorphic?
#1 Jason Svatos
Jason Svatos
  • 1 posts
Posted 14 December 2011 - 11:21 PM
I've done some searching over the past few days and haven't found any results, though forgive me if this is out there and Ive just missed it.
Using an anamorphic lens/adapter on a 16:9 sensor will obviously produce a ridiculously wide image, that will require cropping to achieve 2:35. As the 5D offers a SD mode in 4:3, that would be the easier solution workflow wise I would imagine (considerably lower resolution of course but I may be ok with this.
Has anyone done any anamorphic tests with the 4:3 SD mode on the 5D (or any other canon dslr I suppose)?
#2 Oliver Christoph Kochs
  • 323 posts
  • Film Loader
  • Germany
Posted 26 December 2011 - 12:47 PM
You can use one of the ridiculously expensive ISCOrama lenses. These have a 1.5x sqeeze. Very good filming in HD for scope aspect ratios. Will work with 50mm lenses up on a 5D and 35mm and up on a 7D or similar APS-C sized sensors.
#3 Oliver Christoph Kochs
  • 323 posts
  • Film Loader
  • Germany
Posted 26 December 2011 - 12:48 PM
Has a 58mm thread, so it only works with the smaller Canon lenses.
