Mitchell vs 150mm Ball
11 replies to this topic
#1 dean tsolakis
dean tsolakis
  • 9 posts
Posted 28 December 2011 - 02:47 AM
G'day People,
Forgive my ignorance in this topic, don't know much about Camera support in general
Was considering a Cartoni head with Mitchell compatibility, I myself reside in Australia where i think 150mm ball is predominate as in Europe i suspect,
My RED one personal kit will never really succeed 45 lbs, so 150mm ball makes sense to me, and it seems easier to find legs for Mid Level Spreaders than
with Mitchell flat mounts, i Hate ground Spreaders!!!! only because of location shooting and versatility
I would like to hear your views about this subject, sorry if this topic has been posted previously
Regards,
Dean
#2 K Borowski
K Borowski
  • 3905 posts
Posted 28 December 2011 - 03:51 AM
Not sure if you are in some sort of hurry, this is for a class question, or what, but I really see no reason with this question in particular, to post it multiple places. It's a question about heads, not a stock you might have underexposed, some sort of horrible mishap, a shoot in 2 hours, etc.
Please follow proper courtesy and the etiquette here of not posting the same question all over the place. It clutters the place up and basically asks people to answer the same question in different spots (think about it). Thanks.
#3 Brian Drysdale
  • 5196 posts
Posted 28 December 2011 - 04:00 AM
The 150mm bowl should be fine with your rig. If you want to want to use a mid level spreader, its non availability with a Mitchell mount will make the decision for you. I suspect the reason for them not having the option is that the mid level spreader has come from a documentary/news background and the Mitchell is from a film drama/commercials background, which tends to use the heavy duty range of tripods.
Often the Mitchell mount is used on the dolly and having a compatible head is useful for that, but you can get a bowl adapter anyway. As mentioned in the other thread, the Mitchell mount is keyed and much more solid, it's the mount you use with a gear head.
#4 Chris Millar
Chris Millar
  • 1642 posts
Posted 28 December 2011 - 04:23 AM
He posted it here because another forum member suggested he should.
#5 dean tsolakis
dean tsolakis
  • 9 posts
Posted 28 December 2011 - 05:20 AM
Yeah Thanks for that Chris, Appreciate it! Some people just go off the deep end, don't they?
#6 Doyle Smith
Doyle Smith
  • 8 posts
Posted 17 February 2012 - 01:19 AM
G'day People,
Regards,
Dean
Good question. One element not mentioned is that with a heavier camera/lens/gearhead type (Panaflex/6:1/1000'mag/Panahead) rig, it is quicker for a trained asst. to level a flat-top Mitchell tripod or tweak the 4-way jack screws on a dolly than to wrestle a 150mm ball with a big load. That said, in the 45# range you have w/ your Red you are probably better off w/ a ball head.
On the ground spreaders, I hate 'em too. A carpet square with two grommets and sash cord ties work much better.
#7 Chris Keth
Posted 17 February 2012 - 03:20 AM
Really? So you're never, ever going to put a zoom on your camera? You add standard stuff to a body like a cinetape, an MDR, an onboard monitor and then an angie 12:1 with a 6x mattebox and it's more than 45# and that's not even including the head yet.
#8 Natalie Cremer
Natalie Cremer
  • 1 posts
Posted 19 February 2012 - 06:50 PM
Hello, Chris Keth!
The Cartoni head should be fitted with a Mitchell adopter plate which is sold by independent shops or rented by rental houses.
The carpet idea instead of a spreader is good.
Good luck,
Natalie
#9 Tom Jensen
Tom Jensen
  • 1234 posts
  • Dallas, TX
Posted 20 February 2012 - 01:02 AM
I loathe ball heads and tripods. For 16 they are OK but for 35 go with a mitchell. It sucks when they slip and you have to crank the tie down.
#10 Bruce Greene
Bruce Greene
  • 571 posts
Posted 20 February 2012 - 12:28 PM
I agree Tom, but Mitchell can be very hard to find in Europe and maybe down under. He might find it impossible to find a dolly without a bowl mount.
That has been my experience in eastern Europe at any rate.
#11 Chris Keth
Posted 20 February 2012 - 03:08 PM
Hello, Chris Keth!
Good luck,
Natalie
In my opinion, adapter plates generally aren't acceptable substitutes for the correct tools. Adapters just add slop in places where it's not acceptable.
#12 Tom Jensen
Tom Jensen
  • 1234 posts
  • Dallas, TX
Posted 20 February 2012 - 10:38 PM
Spreaders suck and adapter plates get lost or misplaced when you need them. There are no short cuts in film, only more efficient ways of doing things the right way.
