Gemini
#1 Sean Elder
Sean Elder
  • 76 posts
  • Houston, Texas
Posted 28 December 2011 - 04:38 PM
If anyone can help I would be immensely grateful!!! I'm having an issue with a Gemini that the company I work for has purchased. I am setting up an F3 with S-Log and sending signal via the supplied BNC connectors and on the Gemini, and one of these situations happen. 1)108024fps 4:2:2 single link 2) HD SDI port "A" says 108024fps 4:4:4, HD SDI port "B" says 108024fps 4:2:2 3) both HD SDI and SDI ports have 108024fps 4:4:4 with "signal mismatch" message. I've looked on the Convergence Design forums and no one seems to have this issue, so I wonder if it's something I'm doing or does this Gemini not like me :( !!!
Thanks in advance!!!
#2 Andy Mangrum
Andy Mangrum
  • 1 posts
  • Colorado Springs Colorado
Posted 29 December 2011 - 11:30 AM
Hello Sean,
This is Andy with Convergent Design, If you remove and reinsert the SDI A or B the Gemini should then detect the 4:4:4 correctly,
Another thing you can try is to remove the power and reinsert the power, and it should detect it correctly on power,
If you have any more Question's feel free to contact us directly
http://convergent-de...om/Support.aspx
Best Regards
-Andy
#3 Sean Elder
Sean Elder
  • 76 posts
  • Houston, Texas
Posted 29 December 2011 - 02:49 PM
Best Regards
-Andy
Awesome Thanks!!! I'll keep my fingers crossed!
