Lens support for K35 zoom
#1 Nicholas Davis
Nicholas Davis
  • 2 posts
Posted 04 January 2012 - 04:39 AM
Hey guys, long time reader, new poster. I have acuired a k35 zoom to go along with my primes, does anyone know of the BEST support for this lens, I am building a new system that could be 19 or 15mm, leaning towards 19, if you could help me out from experience or send me to a discussion on this it would be very much appriciated. Thanks!
#2 Dom Jaeger
Dom Jaeger
  • 1728 posts
  • Melbourne, Australia
Posted 04 January 2012 - 08:55 PM
One solution would be 2 semi-circle brackets that screw together with a support rod coming off one. Needs to be fitted to a non-rotating part of the zoom, like the zoom index ring. Measure the diameter and have a machine shop make one up. The support rod would also need to be custom machined to the right length, depending on the lens support you use. Arri lens supports have a couple of mm of height adjustment, from memory it's something like 94mm from centre of lens port to support.
The other alternative is to find a ready-made bracket appropriate to your lens support that is slightly larger in diameter than the fixing point of your lens (index ring or whatever) and use a spacer ring, rubber strip or camera tape to get a snug fit.
It's worth spending some time getting it right, a heavy zoom incorrectly supported can distort a camera lens mount and throw out the flange depth. When a zoom is properly supported the mount locking ring should lock and unlock smoothly.
