Running a TV-logic VFM on V-lock battery
#1 Stefan Bruylants
Stefan Bruylants
Posted 15 January 2012 - 08:14 AM
Hi all,
I was wondering if anybody already tested if you can run a tv-logic VFM-056 on a v-lock battery.
The monitor is rated 7 to 12V and V-lock batteries output, depending on the charge, something between 12 and 17V... So theoreticly that would be to much power.
Any hands on experiences?!
CheerS
#2 William Coss
William Coss
  • 37 posts
Posted 18 January 2012 - 10:26 PM
I did it all day today with an AB 90HC that are new and fully up. Call Bandpro and ask them. I can't imagine a manufacturer putting a battery receiver on their product if it wasn't designed for the voltage.
TVLogic
VFM-071
#3 Joshua Reis
Joshua Reis
  • 108 posts
Posted 11 March 2012 - 03:36 PM
Hi, I have a VFM-056WP that I regular power via the manufacturers "mini XLR to D tap cable" running on a wide variety of onboard camera batteries (Anton Bauer, IDX, Red.)
#4 Matt Irwin
Matt Irwin
  • 389 posts
Posted 23 March 2012 - 12:46 PM
Be careful when running the 056WP directly from AB/V bricks.
I own that monitor too and upon speaking with a TV Logic engineer, I learned that the true voltage limit is 15v. Often freshly charged bricks can run as high as 18-20V, which is enough to fry the monitor. Often you'll be ok, but there is a risk.
Best to use a power regulated cable if coming from D-Tap, or if the brick is also powering a camera, pull the plug on the monitor and let the camera power up, then plug the monitor back in.
I had a cable made with an inline 12v regulator that has a Fisher 3 to D-Tap jumper, so it can do either safely.
