Contrast/color shift when exporting ProRes??
#1 Vincent Sweeney
Vincent Sweeney
  • 686 posts
  • LA at the moment.
Posted 01 February 2012 - 06:26 PM
Advice would be much appreciated on this!
I exported a 2 minute scene from a 1080 ProRes HQ timeline, and made it into the same ProRes HQ 1080 file. Filters had been applied and rendered out fully in the timeline.
It's pretty obvious that the new file, when played back, has a contrast and saturation shift. The shadows were bought up and are slightly milky/more grainy, and the color has faded slightly. I assume this is pretty common when dealing with FCP. Is there a known fix or am I doing something wrong? Why would the codec-matching exported file not look exactly the same as my timeline footage?
#2 Chris Burke
Chris Burke
  • 1720 posts
  • Boston, MA
Posted 02 February 2012 - 09:26 AM
Vincent,
Did you export as a quicktime coversion or export as quicktime with current settings and make movie self contained checked? It is not normal for FCP to do this or at least I haven't encountered it.
#3 Vincent Sweeney
Vincent Sweeney
  • 686 posts
  • LA at the moment.
Posted 02 February 2012 - 03:09 PM
I just export a QT as a self contained movie.
#4 Joshua Reis
Joshua Reis
  • 108 posts
Posted 11 March 2012 - 03:28 PM
Hi, what are your sequence settings? Go to Sequence Settings > Video processing and look at your color processing settings. Are you rendering YUV or RBG? Also, are you able to view your quicktime via a hardware device such as a Kona or Decklink card via HDSI to a calibrated HDSI monitor? If you re import the clip into final cut, are you able to confirm the color shift using the built in vectorscope?
Joshua
#5 Stuart Brereton
Stuart Brereton
  • 3346 posts
Posted 11 March 2012 - 03:59 PM
I'm pretty sure this is a Quicktime issue, not FCP. Google Quicktime Gamma shift for more....
#6 Phil Rhodes
  • 12167 posts
Posted 11 March 2012 - 05:13 PM
This is indeed notorious in Quicktime.
We really do have to get rid of that technology...
#7 Travis Gray
Travis Gray
  • 209 posts
  • Boston, MA
Posted 11 March 2012 - 05:36 PM
Curious now... how does everyone export out of FCP?
My typical process is FCP, send to color, send back to FCP, then export movie and work in compressor from there. And my timeline/footage settings are regular ProRes, 1080p. I haven't noticed any issues yet, but then again, my eyes probably aren't that sharp for these things yet.
