Matching fluorescent with Kino's
#1 Iain Trimble
Iain Trimble
  • Lawrence, Kansas
Posted 08 February 2012 - 11:11 AM
Would you put some plus green over daylight kino tubes to match fluorescent light?
#2 Adrian Sierkowski
  • 7368 posts
Posted 08 February 2012 - 11:54 AM
It depends on if the tubes need plus green. A color meter would be handy here..
You could also just get the same type of tubes used in the overheads and put them on your Kinos, then throw the appropriate minus green filter on the camera.
Lots of ways to do it.
#3 Jon Rosenbloom
Jon Rosenbloom
  • 713 posts
Posted 14 February 2012 - 12:11 PM
I second Adrian's advice to just put matching tubes in your Kino's. The tough part, though, is if you've got light sources other than those Flo's. Anything that's not green will be captured magenta.
#4 Drew Maw
Drew Maw
  • 26 posts
  • Hollywood, CA
Posted 14 February 2012 - 02:22 PM
But how do you deal with flicker? I was in a conversation just yesterday about this very thing: a DP used fluorescents and was able to avoid recording the infamous flicker lines. I know you can adjust shutter speed/angle to deal with it, but it never gets rid of it completely...
Also, you can put standard fluorescent tubes in kino banks? Why would someone do that?
#5 Matthew Parnell
Matthew Parnell
  • 289 posts
  • Electrician
  • Brisbane, Australia
Posted 15 February 2012 - 07:46 AM
If you are shooting in an office where there are 8 rows of 10 fluro fittings. Each fitting has two tubes. That's 160 fluro tubes you have to firstly acquire, secondly swap out and trouble shoot(there is always that one fitting with issues) then thirdly once you are done shooting you have to swap them back to the way they were. That's an awful lot of labour and cost.
Or you could change the 12 tubes in your three 4'Quad kinos to the same tubes as the overheads to create a consistent colour bias across the whole image that can be corrected either using a filter on the camera, or in post.
#6 Matthew Parnell
Matthew Parnell
  • 289 posts
  • Electrician
Posted 15 February 2012 - 07:53 AM
As for the flicker it depends on the fittings. Some have the older style induction ballasts that operate at mains frequency, whereas others have high frequency electronic ballasts that are much more friendly. Given that it can be quite difficult to tell the two types apart, It's wise to just stick to the old Flicker Free Safe Speed charts. Some CMOS chip camera's rolling shutter issues can be painful, but that's the drawback of the tech.
#7 Drew Maw
Drew Maw
  • 26 posts
  • Hollywood, CA
Posted 15 February 2012 - 05:01 PM
Gotcha. So just shoot at 30p (29.97) and convert to 24p in post?
