e6 processing
#1 Pierre P Blais
Pierre P Blais
  • 13 posts
  • Montreal
Posted 11 February 2012 - 06:47 PM
I was wondering, how long can I keep unmixed e-6 chemical component from the single use kit before they lose their properties?
The kit yields 5L and that's a bit much for a single use, considering my lomo thank only uses 1.5 litres about, and I rarely process more then 200ft-400ft per 4 week period, if that. So I'd much rather mix smaller quantities of the solutions, when I need it.
thanks!
Pierre
#2 Charles MacDonald
Charles MacDonald
  • 1157 posts
  • Stittsville Ontario Canada
Posted 11 February 2012 - 08:26 PM
Firstly, I am assuming that it is an all liquid kit, partial mixing of powders is a problem.
Most of the liquid chems are packed with a shot of nitrogen in the top of the bottle to keep the air under control. It is exposure to the air taht causes problems. Many photographers will use small glass bottles and re-pack the remainder of stock solutions to exclude air
#3 Pierre P Blais
Pierre P Blais
  • 13 posts
  • Montreal
Posted 12 February 2012 - 12:50 AM
This is the liquid version i'm talking about yes.
That is good to know, I would not necessarily have thought about doing that, but since I have the glass bottles... now I will! thanks!
#4 Brian Pritchard
Brian Pritchard
  • 330 posts
  • Rushden UK
Posted 12 February 2012 - 04:39 AM
The other trick I discovered many years ago in still photography is to put glass marbles into the bottle to keep the bottle full and exclude the air. I still use this technique for my B/W developers.
Brian
#5 Chris Millar
Chris Millar
  • 1642 posts
Posted 12 February 2012 - 05:57 AM
last year I used some Tetenal 3 bath opened and left half filled from 2003. Worked, I did soup it sliiiiightly longer I think in the first dev though, but heck it looked nice to me
#6 David Nowak
David Nowak
  • 4 posts
Posted 12 February 2012 - 09:10 AM
Chem stability depends greatly on storage conditions as well as how much oxygen it's exposed to. Storing them in air tight containers (you can also displace some of the oxygen in a partially full bottle with a bit of canned air or nitrogen) in a cool, dry environment will work better then a hot, humid environment.
That said, I've had better luck with my E6 chems than with the C41. The E6 has lasted months in partially full bottles where the C41 part C developer oxidized within weeks. :(
