Over sky
#1 Rob Smith
Rob Smith
Posted 03 March 2012 - 06:00 PM
Hi
Have just shot some footage with a 550d which has come back with the sky badly blown out. I exposed correctly for the person in the shot but this meant the sky was too bright. When graded the highlights are not salvageable.
What can I do when I film it again? For the shots I'm getting a graduated filter isn't really going to work. I shot using the neutral picture style, I've heard about the cinestyle profile, will changing the profile help?
Also the day we shot it was misty and the sky was naturally white with clouds as opposed to a clear blue sky.
Hope someone can help
#2 Dominik Belancic
Dominik Belancic
  • 13 posts
  • Sinj, Croatia
Posted 26 January 2014 - 12:08 PM
Bounce the light on to the subject so that you can darken the image and still have the subject properly exposed. Also using log picture styles on dslrs isn't the best thing to do since they are usung an incerted conrast curve so you will get banding and noise issues.
#3 Will Barber
Will Barber
  • 107 posts
  • NYC
Posted 26 January 2014 - 02:52 PM
In addition to brightening the subject with a bounce or lights, just try to avoid the sky in the shot if possible. Using longer lenses and thinking a little more about the background can help with that.
#4 Dominik Belancic
Dominik Belancic
  • 13 posts
  • Sinj, Croatia
Posted 26 January 2014 - 03:54 PM
You could also do sky replacement in post. This isn't my favorite since I like to get as most as possible in camera, but sometimes you gotta do what you gotta do and you can also make the sky looking just the way you want it to look with this method.
#5 Phil Rhodes
  • 12161 posts
Posted 26 January 2014 - 04:49 PM
There is often nothing that can be done in camera about this. I can only reiterate the advice of previous posts: redesign the shot so you can use a grad, redesign the shot to avoid sky, or at least put some trees or other breakup between you and it, or illuminate the subject.
This is one of the problems of shooting in overcast. It's often said that overcast is easy because the light doesn't change, but this is a key issue with it.
#6 David Mullen ASC
  • 20068 posts
Posted 26 January 2014 - 06:02 PM
I believe you can lower the contrast further within the Neutral profile, which may help a little.
Other than that, if you can't use ND grad filters, the you only have one choice (besides switching to a raw or log camera with a wider dynamic range) -- set the exposure to hold detail in the sky and then lift the face with bounce cards, reflectors, or lights to hold detail in the shadows.
#7 Phil Rhodes
  • 12161 posts
Posted 26 January 2014 - 06:52 PM
That might get you half a stop. You might get half a stop more by decreasing the contrast by two or maybe three clicks (test carefully) in the presets for whatever picture style you're using. This probably won't solve the problem.
It may be easier to overwhelm the daylight and brighten your actors if you shoot near dusk.
