NiMH Batteries in a Beaulieu 6008
#1 Paco Sweetman
Paco Sweetman
  • 49 posts
  • London, UK
Posted 04 March 2012 - 07:25 PM
I was going to start using 6 Duracell Rechargeable NiMH batteries in my Beaulieu 6008pro.
Does it matter that the NiMH batteries are 1.25v compared to the 1.5v that are in the Alkaline batteries?
#2 Bjorn Andersson
Bjorn Andersson
  • 18 posts
Posted 06 March 2012 - 04:56 AM
You shall without any probem be able to use 6 pcs NiMH cells. Camera is constructed for use with 1,2V Nicad cells and 1,5V Alkaline.
#3 Paco Sweetman
Paco Sweetman
  • 49 posts
  • London, UK
Posted 06 March 2012 - 08:24 PM
Thank you Bjorn.
#4 Andries Molenaar
Andries Molenaar
  • 688 posts
  • Amsterdam
Posted 08 March 2012 - 02:44 PM
Well, you will need to keep then them charged fully. When full their voltage is lsightyly higher. Like 1.3-1.45
The camera works best with 9volt and plenty of current available. The performance of the camera dimishes when the voltage drops.
I.e. the built-in intervalometer turns unreliable. The exposure system is less agile. Electrozoom goes slower.
The original Beaulieu powerpack based on NiCd has 7 cells rather than 6. 7 cells produce 8.4 nominal.
#5 Bjorn Andersson
Bjorn Andersson
  • 18 posts
Posted 08 March 2012 - 03:12 PM
The 8,4V power pack from Beaulieu was invented in first hand to secure the drive/running when 60m sound cartidges was used. This cartridges sometimes was a bit uneven to drive and sometimes rised the power consumtion a lot in pikes. It´s not the voltage that is important its the amps in battery that secured the camera running. These cartridges are no longer aviable and such problem will not show up. If your camera is in good working condition you will not have any problem.
#6 Andries Molenaar
Andries Molenaar
  • 688 posts
  • Amsterdam
Posted 18 March 2012 - 04:56 PM
Just give it a try? It doesn't hurt your camera. Monitor the responsiveness of the camera, zoom and EE system
Good luck,
