Colour temperature
#1 Baburam
Baburam
  • 16 posts
  • Kathmandu, Nepal
Posted 29 March 2012 - 10:38 AM
Is it true that we can shoot in RED (without setting colour temperature) no worry about colour temperature?
#2 Adrian Sierkowski
  • 7361 posts
Posted 29 March 2012 - 10:45 AM
No.
It is true that you can "change" the color temperature later on. However, the sensor has a native balance of about 5500K- daylight. By changing it, either in camera or in post, you are simply increasing or decreasing gain on the color channels-- though "in camera change" is a bit odd as it's really just meta-data at that point. For best results, it is suggested that you shoot @ 5600K with 5600K lighting, says me. (This is truest on the older "M" Chips, but also carries over to the MX line IMHO).
#3 Hugo Miro
Hugo Miro
  • 12 posts
Posted 29 March 2012 - 01:09 PM
What about the Alexa?
#4 Adrian Sierkowski
  • 7361 posts
Posted 29 March 2012 - 01:11 PM
Same. All silicon based sensors, as far as I know, are biased towards a daylight balance. White balancing any of them just changes the gains, though I'm not 100% on what "daylight" the Alexa is by default, but I'd suspect 5400~5800K with 5600K being the most likely.
#5 Baburam
Baburam
  • 16 posts
  • Kathmandu, Nepal
Posted 01 April 2012 - 09:17 AM
No.
Thanks a lot.
#6 Victor Lazaro
Victor Lazaro
  • 10 posts
Posted 23 June 2012 - 08:07 PM
Which bring us to the next question:
Would you rather change the CT in in the settings (wether on camera or in post), or use CT filters?
#7 David Mullen ASC
  • 20068 posts
Posted 23 June 2012 - 08:20 PM
Depends on how noisy the blue channel gets at the lower color temp settings. For the average dialogue scene, the noise level is fine at standard ISO at 3200K settings on cameras like the Alexa, F65, Epic, etc. I was fine with it even on the MX Red One. For blue screen work, you may want a cleaner blue channel so working closer to 5600K would help.
