Testing film
#1 John Mackey
John Mackey
  • 24 posts
Posted 31 March 2012 - 06:50 PM
Is there a way to cut off about 100 feet of film off of a 400ft roll so that I can test it in a Bolex?
#2 Charles MacDonald
Charles MacDonald
  • 1157 posts
  • Stittsville Ontario Canada
Posted 31 March 2012 - 07:20 PM
yes.
Same way you would use if you were breaking the roll down to fit a bolex.
IN the darkroom, run the roll on a rewind, (normally in a split reel to prevent it from unwinding.) Spool off as much film as you want to another rewind. A 100ft spool will work here. You can rest your thumb on the flange to judge when you have a full spool.
Cut the film and return it to the can, then REWIND the 100 ft spool onto another 100ft spool. You can put that in a box, or right into the camera. Be sure the (now 300ft) roll is bagged and sealed, and mark it as a 300ft short end.
I often use this process to break ends down to fit my Filmo, although in that case I run the whole roll onto a vintage 400ft spool, and rewind that on to 100 ft spools. I use the 400ft spool to reduce the risk of accidental exposure.
Edited by Charles MacDonald, 31 March 2012 - 07:21 PM.
