Aaton Digital Camera
21 replies to this topic
#1 Brian Drysdale
  • 5218 posts
Posted 14 April 2012 - 03:10 AM
Just looked at the latest Aston sheet for the digital Penelope, no doubt just out for NAB.
http://www.aaton.com...april-2012b.pdf
The interesting bit is how they're achieving the camera's lower ISO rating by using a multi slot shutter with a 100 ISO setting, so avoiding the use of ND filters. I was wondering how they were managing it. I expect there'll be a lot of testing for artifacts from this new arrangement.
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 14 April 2012 - 04:52 AM
The 100 ISO shutter looks like a very clever soloution.
#3 Tim Tyler
Tim Tyler
    Administrator
  • Admin
  • 1295 posts
  • Olympia, WA (US)
Posted 30 April 2012 - 09:47 PM
CCD eliminates rolling shutter issues.
http://www.aaton.com...cts/film/delta/
The first optical viewfinder digital camera with an internal SSD recorder (DeltaPack*) for full rez CineDNG ucompressed RAW (the Adobe archival format based on open standards), and editorial-ready proxies.
* DeltaPack is compatible with the codex® backstage and post station workflow.
Lightweight: 7.5 kilos with internal recorder and two onboard 14V Li-Ion batteries. Two to five hours‘ autonomy; power dovetailing during changes.
Designed for earthlings, Delta respects Aaton‘s first commandment : Cat on the Shoulder profile, plus wide flat base for tripod. No eye-strain bright viewfinder with large peripheral coverage. . Rotating mirror shutter; no rolling shutter artifacts.
Main selector eliminates complex menu navigation and gives direct access to operating functions from both the operator and assistant sides.
Location sound-mixer friendly, Delta is noiseless in both record and pause ( <19dB ) and offers AES42 input for digi-mics as well as RF transmitted mixdown from audio recorders.
Unlimited number of cascadable preset 3D LUTs for RAW metadata on one hand, and for on-set control screens on the other.
14 stop dynamic range Super35 Dalsa® CCD sensor, 800 and 100 ISO sensitivities (patent pending) eliminate the need for special anti-IR neutral density filters. 90% pixel-fill allows for wide angle lenses with short exit-pupil distance. 
#4 Keith Walters
Keith Walters
  • 2252 posts
  • Sydney Australia
Posted 30 April 2012 - 10:19 PM
Do they state the sensor's native resolution anywhere? All I can find is:
"Dalsa® sensor’s 90% pixel-fill allows for 7K pixel sampling"
If you can afford the mirror shutter, Dalsa's simple 40-year-old CCD design still gives the best results, since almost the entire silicon area is used for photon capture, without the complication of microlenses.
#5 Chris Millar
Chris Millar
  • 1642 posts
Posted 01 May 2012 - 01:05 AM
Looks like a fine piece of engineering...
er, so can anyone explain what a '100 ISO' shutter is ? (last time I looked up a patent I remember thinking never again)
Whats going on with those slits ?
#6 Brian Drysdale
  • 5218 posts
Posted 01 May 2012 - 01:19 AM
I assume it's a means of reducing the amount of light passing through, without reducing the effective shutter angle. I guess it acts as a series of travelling slit shutters, which combine to provide the complete exposure.
#7 Vincent Sweeney
Vincent Sweeney
  • 686 posts
  • LA at the moment.
Posted 01 May 2012 - 01:49 AM
Does this mean that non-film movie cameras will finally be able to record red lights without them turning white and/or pink? Current digital nighttime street shots are already looking dated.
Any word on shipping dates or price?
#8 Chris Millar
Chris Millar
  • 1642 posts
Posted 01 May 2012 - 02:06 AM
Ah, ok - I (mis)read 'multi-shot' in your first post which got me thinking too much... Yup, I get it, and you've already touched on temporal aliasing issues which was my next thought.
#9 Matt Stevens
Matt Stevens
  • 705 posts
Posted 01 May 2012 - 09:09 AM
Wow. How many tens of thousands will this pupppy command?
Edited by Matt Stevens, 01 May 2012 - 09:10 AM.
#10 Michael Lehnert
Michael Lehnert
  • 1095 posts
  • London, UK / Basel, CH
Posted 01 May 2012 - 12:00 PM
Funny: Jean-Pierre Beauviala in signature dress featuring in the photo on page 3 of the Aaton PDF brochure Brian posted originally. B)
#11 Keith Walters
Keith Walters
  • 2252 posts
  • Sydney Australia
Posted 01 May 2012 - 08:57 PM
We also now need a new folder; clearly this doesn't fit in "Aaton Film".
Why not just "Aaton" since there aren't that many Aaton-related posts?
Or is that about to change...? :rolleyes:
#12 Tim Tyler
Tim Tyler
    Administrator
  • Admin
  • 1295 posts
  • Olympia, WA (US)
Posted 03 May 2012 - 09:21 PM
I think just renaming this forum will do the trick.
#13 Michael Lehnert
Michael Lehnert
  • 1095 posts
Posted 04 May 2012 - 05:27 AM
I second that motion!
I think 'Aaton' or 'Aaton Film + Digital' would do the job.
#14 Brian Drysdale
  • 5218 posts
Posted 12 September 2012 - 01:18 PM
Some pictures and info from IBC
http://www.fdtimes.c...penelope-delta/
#15 Brian Drysdale
  • 5218 posts
Posted 29 September 2012 - 01:04 AM
Here's an article by on the Penelope Delta with some test DNG frames..
http://blog.abelcine...enelope-camera/
#16 Chris Millar
Chris Millar
  • 1642 posts
Posted 29 September 2012 - 03:14 AM
Moving the sensor half a pixel - very interesting! ;)
'7k' though - not sure how to achieve it without having your screen and or projection also moving half a pixel every frame - huh?
#17 Brian Drysdale
  • 5218 posts
Posted 29 September 2012 - 11:29 AM
Interesting to find out theory behind that, it could be a perceived "dynamic" resolution over a number of frames as against a stand alone single frame resolution. The Camera records RAW, so there could be a bit of post processing going on.
Here are some test images:
http://www.marquise-...ces.html#tabs-5
#18 Chris Millar
Chris Millar
  • 1642 posts
Posted 30 September 2012 - 07:10 AM
Thing is the end product has a single frame resolution... But one of 7k? Oversampling? To be used in? VFX/comp work?
#19 Brian Drysdale
  • 5218 posts
Posted 12 October 2012 - 02:08 AM
I believe there are 20 slits and looking at some still frames in a CML thread the motion blur does look pretty normal on the number plate of a moving car.
#20 Brian Drysdale
  • 5218 posts
Posted 16 November 2012 - 02:49 PM
The first Digital Penelope has been delivered.
http://www.fdtimes.c...pe-d-delivered/
  • 1
