ND Filter for Double X 7222?
#1 TW Foley
TW Foley
  • 20 posts
Posted 18 April 2012 - 08:11 AM
If I'm shooting in the middle of the afternoon in a neighborhood full of bright colored houses on a sunny day, and I am using Kodak Double X 7222, do I need a neutral density filter?
#2 Kip Kubin
Kip Kubin
  • 131 posts
Posted 18 April 2012 - 03:57 PM
You should have ND's at hand. + POLARIZER for managing/shaping reflective glare on skin tones and grass/brick/windows etc
Depending on the color of the houses and what you want to emphasize you may want use color filters as well.
Today, as an example my meter @250 is showing T22.. Do you have a meter? That would be the easiest answer...what stop do you want for the film you have.
Id normally start with 2 stops and a Polarizer for the setup ..but I'd have the other ND's there depending on the story.
#3 Charles MacDonald
Charles MacDonald
  • 1157 posts
  • Stittsville Ontario Canada
Posted 18 April 2012 - 06:00 PM
If I'm shooting .... sunny day, and I am using Kodak Double X 7222, do I need a neutral density filter?
Anything much faster than about ISO 25 in bright sunlight will be easier if you have a ND filter available.
24FPS is effectively a /50th to 1/60th Shutter speed. The famous sunny 16 rule would mean ISO 50 film would require f/16 at 1/50th in bright sun. ISO 250 is more than 2 stops faster. so as has been stated you would have to crank it down to f/22 or even f/32.
Some ND would allow a larger appature in order to control your Depth of Field.
If the world was perfect Kodak would still sell XT Pan. which at ISO 25 was perfect for bright days.
#4 Robert Houllahan
Robert Houllahan
  • 1626 posts
  • Providence R.I.
Posted 18 April 2012 - 07:18 PM
We see allot of overexposed 7222 at Cinelab so the idea of some NDs and a Polarizer is good and I would add some yellow filters to that kit too. Also think about Orwo UN54 for outdoors...
-Rob-
