EI RATING for digital cameras
#1 jaysonwilko
jaysonwilko
  • 13 posts
  • P.A.
  • Missouri
Posted 15 May 2012 - 04:30 PM
I am a bit confused about something that probably has a simple answer. I am confused about rating cameras with the 18% grey card test. RED, the Alexa and many other digital cinema cameras have a range of IE settings but I keep reading about DPs "rating a camera" at a particular EI (RED 320, Alexa 800, and so forth) is this simply the EI that is the optimal EI setting for that particular camera or am I missing something else here? This has been bugging me for a while as I learn more and more.
Love to hear the answer and thank you for sharing your knowledge with a guy just getting started.
Jayson L. Wilkins
#2 Adrian Sierkowski
  • 7409 posts
Posted 15 May 2012 - 06:04 PM
You've got it right. It's the EI which renders either or both the most dynamic range or the least amount of noise. The sensors in a camera, like a film stock, have a certain response to light quanity when it hits the system; so they work that out to an "optimal" ISO/EI/ASA pick the acronym you'd like (though not DIN, because of the war). And when you change it in camera or in post, you are either adding or removing gain.
#3 jaysonwilko
jaysonwilko
  • 13 posts
  • P.A.
  • Missouri
Posted 15 May 2012 - 07:05 PM
Thank you for the response. I am very pleased. That question has been gnawing at my brain for a while.
