1000ft cores on 400ft mag??
#1 Evan Andrew John Prosofsky
  • 148 posts
  • Canada
Posted 28 May 2012 - 11:26 PM
Hi Everybody,
Just a quick question here:
Wanted to confirm if it is possible to use a short end originated from a 1000ft load (300ft now) in a regular 400ft mag. Are the cores different? Is there anything I should know? And vice versa, can I use a 300ft short end originated from a 400ft load in a 1000ft mag? Specifically I am referring to the arriflex 35 III, but I'd assume the rules would be the same across all cameras?
Hope that makes sense. Thanks very much!
Evan
#2 Stephen Murphy
Stephen Murphy
Posted 29 May 2012 - 02:55 AM
Hi Everybody,
Evan
The plastic cores are the same size so if you're using a magazine that uses them you're fine.
#3 Will Montgomery
Will Montgomery
  • 2085 posts
  • Dallas, TX
Posted 29 June 2012 - 02:44 PM
Some Arri 400' mags don't have removable cores on the take-up side; you just slide off the roll, put it in the can and write "no core" on the can.
