Paillard Bolex H16, need some help
#1 Markus Ottosson
Markus Ottosson
  • 1 posts
Posted 02 June 2012 - 03:09 AM
Hi
I bought a Paillard Bolex H16 a while ago that does not look quite like any other, seems like someone has modified some extra accessory to it.
Here are som pictures
A closer look
The darker part of the "disk" is magnetic.
And this is connected the "thing"
I've also uploaded a video so you can see how it works
Bolex H16 - YouTube
Anybody have a clue?
I'm new to these kind of cameras so I have no idea.
#2 Jean-Louis Seguin
Jean-Louis Seguin
  • 754 posts
  • Montreal, Canada
Posted 02 June 2012 - 07:45 AM
Hi
A closer look
Bolex H16 - YouTube
The magnet likely acts on a reed switch which will close once every 8 frames.
It might be to control an external digital frame counter but it wouldn't be very accurate.
Cheers,
Jean-Louis
#3 Dom Jaeger
Dom Jaeger
  • 1755 posts
  • Melbourne, Australia
Posted 02 June 2012 - 07:57 AM
At a guess it's a home-made tachometer, probably used to set the speed as accurately as possible. With each revolution of the disc (8 frames) the magnet will trigger a switch to create a pulse, so exactly 2 pulses per second is 16 fps, 3 pulses per second and you're at 24 fps. Presumably there was a readout box that the plug fitted into.
