Three phase power from venue
#1 Elliott Balsley
Elliott Balsley
  • 11 posts
Posted 15 June 2012 - 10:35 PM
I'm preparing for a shoot in a nightclub, and they have cam-lok tails available for us to use. But nobody at the venue can tell me any more details than that. I need to figure out how much power is available exactly. I took this photo of the fuse box, and it looks to me like 100A per leg for 300A total. Can someone confirm that please? I can see that the cam-lok tails has 3 hots, neutral, and ground.
Also — I'm assuming each phase-neutral is 120v, but what would be the standard voltage phase-phase in this kind of venue? Just curious, in case we have any 240v units.
Thanks in advance for any help!
-Elliott
#2 Rob White
Rob White
  • 24 posts
  • Electrician
Posted 18 June 2012 - 06:09 AM
You seem to be on the right track, although the fuses also say 250v. I would always recommend getting a qualified electrician to have a look if details of the supply are fuzzy - don't want to blow anything up!
Typically with a three phase live to live is 1.73 x line voltage; as the three waveforms are 120 degrees out of sync, and do not peak at the same time.
