window reflection
7 replies to this topic
#1 Bazil Christodoulou
Bazil Christodoulou
  • Greece
Posted 18 June 2012 - 12:51 PM
hi everybody,
this is my first post at the forum and i'm very glad being a member of it.
we are shooting a short in a couple of days in which i'm dop-ing and i want some extra opinions about a shot.
the scene is a man who is walking on a pavement and the frame is his legs from the waist and below with a little pavement.
the camera is moving on steadicam along him by the side at low mode(parallel to him).
from the other side there is a wall and i would like to throw some windows reflection on that wall or maybe on the pavement.
the kind of reflection is that of a window that is hit by the sun making the light hitting the wall transparent just like when you resemble water on a face, this kind of transparency.
i've tried lighting a gel but due to marks or other faults on the gels, the reflection isn't good and constant from side to side
do you have any suggestions?
i hope i made my self clear because i don't know the english terms to explain the situation better
thanks in advance
#2 Martin Hong
Martin Hong
  • 137 posts
Posted 19 June 2012 - 12:11 AM
Have you tried crystal?
#3 David Mullen ASC
  • 20102 posts
Posted 19 June 2012 - 12:36 AM
I don't understand how light hitting a wall can make it transparent or how the light can become transparent when hitting a wall.
#4 Bazil Christodoulou
Bazil Christodoulou
  • Greece
Posted 19 June 2012 - 02:08 AM
ok, maybe i didn't express my self correctly.
when you light a subject with a gel in front of the lamp, the light that reflects back (to the direction of the lamp) looks like water reflection.this is the texture that i mean.but the problem is i want a rectangular shape(window) on the wall and not uneven shape.
if you notice a window hit by the sun you will see what i mean especially in the afternoon
i will try crystal or big pieces of glass.
thanks
#5 Mike Lary
Mike Lary
  • 472 posts
Posted 19 June 2012 - 05:00 AM
thanks
I think I know what you mean about water-like reflections from gels, but your wording is a little odd. Gels (regardless of whether they're mounted in front of a light source) can bounce reflected light in water-like ripples onto walls, and the effect is more pronounced as the gels are more warped or angled from the light's direction. It sounds like you need to create a cookie or to flag a large light source to create the window shape, then work the effect inside that shape. You could also try bouncing light off a bounce board covered in crinkled foil, but controlling the shape of the reflection might be tricky.
#6 David Mullen ASC
  • 20102 posts
Posted 19 June 2012 - 11:15 AM
It's going to be hard to create square or rectangular window patterns where the rippling light pattern is restricted to being inside of that. You'd need a pretty big set-up for that -- imagine a swimming pool in the next room with a wall of windows separating the pool from a corridor, and a single bright, hard specular source is bouncing off of the water, and then through the windows and then throwing a pattern of both the windows and the water ripples on the opposite corridor wall.
That's almost the scale at which you'd have to work, a large pan of water fairly far away reflecting a farther hard, bright source skipping off of the water in the pan (with someone stirring the water), and then a large wall of window cut-outs / cookies between the pan of water and the wall you want the patten to hit.
#7 Jon Rosenbloom
Jon Rosenbloom
  • 713 posts
Posted 20 June 2012 - 10:28 AM
I think I know what you want; we see that light reflected off of windows all the time in New York City. Using actual window glass sounds a little dangerous, though. You could try using square mirrors - which are pretty standard grip/electric items in the US - to reflect the sun, but then you'd still have to create the ripple effect. Maybe if you diffuse the reflections with frames of hampshire frost you can get a little closer to what you want. Or, maybe you just put a crinkled layer of 1/8th or 1/4 blue directly on top of the mirror. Or, you can make some square frames with Rosco shrink mirror gel (http://www.rosco.com...quickTheatrical), but don't shrink it so it stays loose on the frame. Of course, all this depends on working where the sun will help.
#8 David Mullen ASC
  • 20102 posts
Posted 20 June 2012 - 11:27 AM
If he doesn't need the light to ripple with motion like it's being reflected off of water, but have a static ripple like it's being reflected off of warped glass, then it's a bit easier -- it's mainly an issue of multiple square reflecting sources (like panels with some rippled mylar silver) or one giant rippled surface of mylar or something and then a giant cookie of a window pattern to break it up, all at a sufficient distance (light to reflector, reflector to cookie) to maintain sharp patterns.
