Kodak Instamatic M 100 A Super 8 Sound Projector
#1 Glenn Brady
Glenn Brady
  • 329 posts
Posted 21 June 2012 - 07:02 AM
Does anyone here have a working example of the Kodak Instamatic M 100 A Super 8 sound projector? When the machine is plugged in, the motor switch moved to its 'on' position, the selector knob turned to 'thread and silent' position, and the control knob turned to its 'forward' position (24 or 18 frames per second), I assume the sprocket wheels on the machine should turn. On the example I've just received they don't and the film can't be fed into the projector. Has anyone experienced the problem and fixed it? Are there repairers anyone can recommend (if it isn't an easy fix)?
#2 Jean-Louis Seguin
Jean-Louis Seguin
  • 754 posts
  • Montreal, Canada
Posted 21 June 2012 - 09:13 AM
Hi Glenn,
I have the telecine version of this projector and I can check it at later today when I get back home.
What you describe certainly doesn't sound normal. Hopefully, it's just a broken timing belt or something simple.
Cheers,
Jean-Louis
