Steady Car Interior Shot
10 replies to this topic
#1 Jonas Fischer
Jonas Fischer
  • 19 posts
  • Zurich, Switzerland
Posted 25 June 2012 - 04:08 PM
Hello all
I was wondering how one can achieve a steady car interior shot.
I'm pretty sure that a simple tripod won't be steady enough.
Any ideas on how to rig a camera inside of a car?
Thanks a lot for your help.
Regards
Jonas
#2 Brian Drysdale
  • 5287 posts
Posted 25 June 2012 - 05:41 PM
It depends where you're mounting the camera, there isn't a lot of space in most cars for a tripod. Yes, you can get a steady shot with a quality tripod, although I'd tend to lash it down, especially if it's a light one, so that it's not moving independently of the car and any vibrations are damped down.
#3 Sean Elder
Sean Elder
  • 76 posts
  • Houston, Texas
Posted 25 June 2012 - 10:52 PM
There's also the Tyler mini gyro route! It will keep the bouncing around to a minimum, but I'm not sure if panning and tilting is something that you would be able to do effectively inside a vehicle with that setup.
#4 Richard Andy Rosebrook
  • 1 posts
Posted 01 August 2012 - 03:17 PM
I'm working on figuring this out now. A tripod is tricky in a small car. It works ok for out the window shots. I'm buying a glidecam steadycam, I think that should work great from the backseat. For side to side shots I was planning on clamping a camera mount to the window, this would be fine if the car is accelerating smoothly.
#5 Brad Grimmett
Brad Grimmett
  • 2660 posts
  • Steadicam Operator
Posted 01 August 2012 - 09:35 PM
The Glidecam, or any Steadicam, is not a good idea for car interiors.
#6 Bruce Greene
Bruce Greene
  • 621 posts
Posted 02 August 2012 - 12:56 PM
If you could fit a Steadicam in the back seat it would probably need to be a very small one, that you hold in your hand (no arm) with a miniature camera.
The effect would be that the interior shakes, but the view outside is smooth. I have done this in busses and it's worked well with a full sized rig.
If you secure the camera in the car, the outside will shake, but not the inside. If the road is really smooth, everything will be smooth.
My model II from the 1980s came with a compact vehicle kit, but it required a very light weight camera and was really impossible to use. Still too big!
Good luck!
#7 Nicolas Gomez
Nicolas Gomez
  • 36 posts
Posted 18 September 2012 - 10:20 PM
The whole trick is on moving on soft pavement. Its really hard to stabilize otherwise...
http://www.elsotano.com.co/videos.php
#8 Brian Stansfield
Brian Stansfield
  • 5 posts
  • DC/NYC
Posted 06 December 2012 - 11:44 PM
http://www.filmtools...mera-mount.html
I've used this Film Tools car mount before and it's pretty smooth... granted, it's no gyro/stedicam, but with a smoother road it works great. Plus you can suction mount outside the car in virtually any angle with the ball head. Really depends on the composition you're looking to achieve.
#9 Peter Jensen
Peter Jensen
  • 16 posts
Posted 30 December 2012 - 02:33 PM
I've finished a new tool, a small hand held stabilized head - very light and compact and stable and smooth operating, small enough to be passed through open car window.
www.evoheads.com
Best,
Peter Jensen (SOC)
Los Angeles, Ca.
pj@evoheads.com
#10 Tom Jensen
Tom Jensen
  • 1234 posts
  • Dallas, TX
Posted 08 January 2013 - 09:00 AM
Peter, that's pretty cool. Is it silent?
  • -1
#11 Peter Jensen
Peter Jensen
  • 16 posts
Posted 09 January 2013 - 08:24 PM
Yes, Tom.
