Filter tilting options
#1 Tanner Stauss
Tanner Stauss
  • 9 posts
Posted 28 June 2012 - 10:02 AM
Besides Panavision and tape balls, what options are out there for tilting filters? We're constantly running 1/4 and 1/2 Black Diff FX and there is kick back on almost every shot with any kind of hot spot in the frame. We're shooting Scarlet with super speeds and currently running with an O-Box.
#2 Tom Jensen
Tom Jensen
  • 1234 posts
  • Dallas, TX
Posted 28 June 2012 - 10:38 AM
What is an O-Box?
#3 Tanner Stauss
Tanner Stauss
  • 9 posts
Posted 28 June 2012 - 11:25 AM
It is OConnor's lightweight 15mm mattebox.
#4 Chris Keth
Posted 28 June 2012 - 01:28 PM
There are anti-reflection trays for MB18s and MB14s.
#5 Tanner Stauss
Tanner Stauss
  • 9 posts
Posted 28 June 2012 - 01:58 PM
Do you know if those are something that would work in an LMB or an MB-1? We are using 4x5.65 filters by the way.
#6 Chris Keth
Posted 29 June 2012 - 02:11 AM
Well, it's a bit of a cobbled solution but you can take two trays open side to open side and use it like that. Place the bottom of the filter in one tray and the top in the other tray. There should be enough spring in the tray to hold it once you've given it a bit of paper tape top and bottom. It's not a great solution because it wastes a stage, meaning in a 3-stage LMB5 you'll only get 2 filters.
#7 Alec Eriksson
Alec Eriksson
  • 1 posts
Posted 23 July 2012 - 02:26 PM
This may not help you, but perhaps someone else coming along and finding this question and wanting an alternative....
The Letus LTMB1 Matte Box comes with an anti-reflection tray out of the box. It's a bit different from usual matte boxes in that it uses a single deep top-loading tray that doesn't rotate and allows either 3 stacked 4x5.65 filters (set right on each other) or using the tray insert up to two filters at either a slight upward or downward angle. There's also a 138mm round rotary drop-in filter stage at the rear of the box for a polarizer, fader ND 138/4x5.65 combo system, or whatever else you can find in 138mm.
I own the matte box as of last week but haven't had a chance to test out the angled insert, but the rest of the box is quite nice and considerably cheaper than ARRI or OConnor at a similar build quality. Maybe worth a look for you or others. Scope it out at mastercinemaseries.com
Edited by Alec Eriksson, 23 July 2012 - 02:29 PM.
