Blurry Image (not related to focus) through viewfinder
#1 Stuart Eagon
Stuart Eagon
  • 6 posts
Posted 02 July 2012 - 09:41 PM
Last evening when I was out filming with the XTR, I was attempting a shot (on a tripod) which was looking straight up at the top of building (camera almost parallel to skyscraper).
After I changed lenses in between shots, I suddenly noticed that the image that I was looking at through the viewfinder was somewhat blurrier (the focus had not changed at all) than on the previous shot.
I tried all four of my different lenses--to no avail--the image is still blurry...maybe I'm crazy, but it seems even more blurry today than yesterday.
I was thinking that maybe a drop of water got on the mirror or something happened to make it foggy, in between the lense change...cleaning the mirror hasn't seemed to help...
I'm at a little bit of a loss...any ideas?
#2 Robert Lewis
Robert Lewis
  • 180 posts
  • United Kingdom
Posted 03 July 2012 - 02:18 AM
It is not clear what you mean when you say "the focus had not changed at all". Focus of what? The lens or the viewfinder? I am just wondering whether the diopter setting has moved. This could easily happen if the locking screw has worked loose. So, simple check first ... have you checked the diopter setting?
#3 Adrian Sierkowski
  • 7409 posts
Posted 03 July 2012 - 05:37 AM
My bet would also be on Diopter.
#4 Stuart Eagon
Stuart Eagon
  • 6 posts
Posted 04 July 2012 - 03:46 PM
Thank you for your quick responses.
I got it figured out.
For anyone else using the Aaton, make sure to be aware of the diopter on the XTR--the lock for the diopter ring is not the best and it can come loose pretty easily.
#5 Modesta
Modesta
Posted 29 August 2012 - 09:36 AM
I have an Aaton XTR and I just got a adapter for C-mount lenses (PL - C-mount).
Just tried the C-mount lens with the adapter and it's all blurry. Diopter is correct so it's not that.
I've never used this camera before, recently got it. Any ideas?
I got the adapter here:
PL ADAPTER-C-MOUNT LENS
https://www.google.co.uk/#hl=en&output=search&sclient=psy-ab&q=PL+ADAPTER-C-MOUNT+LENS%2C+CONVERT%22C-MOUNT+LENS+TO+PL!+&oq=PL+ADAPTER-C-MOUNT+LENS%2C+CONVERT%22C-MOUNT+LENS+TO+PL!+&gs_l=hp.3...812.812.0.1375.1.1.0.0.0.0.110.110.0j1.1.0...0.0...1c.Op01c7mRDeo&pbx=1&bav=on.2,or.r_gc.r_pw.r_cp.r_qf.&fp=9539be33ebda02e8&biw=1276&bih=660
