RED ONE MX STROBING PROBLEM AFTER FIRMWARE UPDATE
7 replies to this topic
#1 daniel mahlknecht
daniel mahlknecht
  • 190 posts
  • Italy - South Tyrol
Posted 12 July 2012 - 08:23 AM
Hello all,
I encountered a problem after I did the firmware update 31.6.16 on my RED ONE MX.
The footage I shot after this has all a kind of strobing problem,
not only when panning but also with everything moving inside the frame.
I reinstalled the firmware more times following the installing manual.
I tried also to downgrade the camera but the problem remains.
Has someone an advice to give or a solution to this problem?
Thank you
#2 Ibrahim Muhammadi
Ibrahim Muhammadi
  • 4 posts
Posted 19 November 2012 - 06:02 AM
I just bought a used red1 mx camera and found out that it has the same issue of strobing in all shots where anything moves within the frame (even when the camera is fixed).
I tried all shutter speeds and all bitrates, did the black shading too but nothing has worked. Even changed the lens mount and tried on a different lens :(
I am not sure if my problem is related to any firmware upgrade or not because I have not upgraded the firmware and I am not sure if the previous owner did that.
I have an urgent shoot coming up in 2 days and I am stuck with this problem. Would appreciate if you or anybody else on this forum could respond fast.
#3 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 19 November 2012 - 04:05 PM
Hello all,
Thank you
How are you looking at the footage? I suspect you monitors scan rate is not the same as the camera. As there has not been a firmware update you may have forgotten to change a preset, especially if the problem remains when wou roll back the firmware.
#4 Ibrahim Muhammadi
Ibrahim Muhammadi
  • 4 posts
Posted 19 November 2012 - 06:20 PM
Thank you for the response... Really appreciate it...
What is the 'camera's scan rate'?
I am viewing the footage on a 60hz (hp 3065) monitor via adobe premiere cs6. I shot footage on 25fps as well as 29.97 (30 fps) on the camera if that is what you mean by the camera's scan rate. I placed the 30 fps footage on a 30 fps preset timeline and the 25 fps footage on a 25 fps preset in premiere. The stuttering occurs on both frame rates. Is there anything else that I must do (or not do) ?
#5 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 20 November 2012 - 02:32 PM
See what happens if the scan rate is 50hz. This monitor is a computer screen? I suspect it's native resolution is not 50 or 60, that could be an issue.
#6 Ibrahim Muhammadi
Ibrahim Muhammadi
  • 4 posts
Posted 20 November 2012 - 04:09 PM
The monitor is a computer screen with 60hz native. I tried a different computer screen with 50 hz native but the problem persists. It does get a bit smoother at 60hz with 60 fps footage but a large amount of strobing/stuttering still exists.
Would it be gone if I use an LCD TV screen instead of a computer screen or is it necessary to go in for PGM monitors?
#7 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 21 November 2012 - 12:16 PM
I doubt a PC screen is 50 or 60 native, there is a conversion going on. Earlier you said the problem only happened before the firmware are you sure?
#8 Ibrahim Muhammadi
Ibrahim Muhammadi
  • 4 posts
Posted 21 November 2012 - 12:27 PM
I tried the 25fps on a 50 hz TV - still the same... If there is a conversion going on then I do not know about it... The firmware issue was that of another user on this forum (daniel) - I got this camera just about 10 days back from a previous owner. I am not sure if the previous owner got the firmware updated before he gave it to me...
