What sorcery is this? Mini-Mitchell Hihat?
#1 Ricardo Casco
Ricardo Casco
  • 15 posts
  • Grip
  • Houston
Posted 12 July 2012 - 02:17 PM
A while back ago I got a used mitchell hi-hat, seller claimed it was from Matthews. So when It arrived, assuming all mitchell bases were the same, I just stored it incase anyone needed one on set. About a month later it gets called in, so I grab the 150mm bowl adapter and to my surprise it didn't fit! Luckily it was not actually needed that day, but this is a bummer.
Can anyone explain this to me? I thought the mitchell base was a standard size:
Image: Pin not fitting inside slot:
Image: Circular opening too small
I know the adapter is the correct size because its worked on multiple other mitchell bases.
Anyone know who manufactures these?
Edited by Ricardo Casco, 12 July 2012 - 02:17 PM.
#2 Tom Jensen
Tom Jensen
  • 1234 posts
  • Dallas, TX
Posted 12 July 2012 - 07:03 PM
I would say the hi-hat looks right so it could be the adapter.
#3 Ricardo Casco
Ricardo Casco
  • 15 posts
  • Grip
  • Houston
Posted 12 July 2012 - 09:42 PM
Should have mentioned, the adapter has worked with another mitchell part I have, but this would answer the question: The hi-hat's diameter is about 6", the hole is about 2" 1/4 and the little pin receiver is about 1/4" - Is that the correct size for a mitchell base? If someone could confirm that would be great. I'm pretty sure this is a weird mini version, or I must have some sort of oversized mitchell base on a dolly and oversized adapters!
#4 Sanjay Sami
Sanjay Sami
  • 258 posts
  • Grip
  • Anywhere they pay me to go
Posted 16 July 2012 - 12:52 AM
You have discovered one of the most frustrating realities in the grip world.
All Mitchell / Moy fittings are not the same. There are small differences. Place a fisher and chapman mitchell receiver against each other - they dont match.
#5 Paul Bartok
Paul Bartok
  • 223 posts
Posted 16 July 2012 - 12:39 PM
great! :/ meme are starting on here now
#6 Ricardo Casco
Ricardo Casco
  • 15 posts
  • Grip
  • Houston
Posted 25 July 2012 - 08:12 PM
Gah! At least we all agreed what the baby pin and junior pins sizes are, if not Im probably going to go live in a cave somewhere.
Managed to sell it, maybe it will be of use to someone else
