Is this lighting doable
#1 David Ellison
David Ellison
  • 5 posts
Posted 01 August 2012 - 04:40 PM
Hi all,
I would like to pull off some unique lighting idea for a project I saw something similar on another project.
Basically it involves using a light of somekind to create a narrow beam of light that has as little feathering across as possible and can be used to flash over a car.
As though the light was a beam around three to four inches across and as long as the shot requires so we can see it 'scan' over surfaces.
The image I found is this.
Couldn't this be a simple practical lighting effect which would make the days shoot far easier to control than doing multiple passes or VFX.
It would be great to hear from you all.
  • 20246 posts
Posted 01 August 2012 - 06:59 PM
A Source-4 Leko could create a sharp pattern like that but whether it would be wide enough to cover a car is unlikely, that sounds more like a laser beam.
#3 David Ellison
David Ellison
  • 5 posts
Posted 01 August 2012 - 07:46 PM
It's not meant to cover the entire car, just sections at a time so a beam three inches or so wide and as long as I can get it hopefully at least two to three feet long.
#4 David Mullen ASC
  • 20246 posts
Posted 01 August 2012 - 08:17 PM
You can create that with the blades inside a Source-4 Leko. The brightest would be a Joker 800 HMI Source-4 Leko conversion. The brightest tungsten is the 750w version.
If you want two stripes with one light, you'd need to order a special gobo for the Leko with that pattern.
#5 David Ellison
David Ellison
  • 5 posts
Posted 02 August 2012 - 01:47 PM
Just the one stripe.
Appreciate the help. Very kind of you.
